-   -   Need Hose: Heat Exchanger To Flapper Box (http://forums.pelicanparts.com/porsche-911-technical-forum/521799-need-hose-heat-exchanger-flapper-box.html)
Davie Boy 01-16-2010 08:04 PM
It looks like Pelican has an OEM hose for $27. Is that really what I gotta spend? Does anyone have something aftermarket and cheaper? Auto parts places carry "pre-heater" hoses that look perfect, but they don't carry anything larger than a 2" diameter. Home Depot and Lowes carry some similar 3" diameter hoses, but they fall apart when you try to get them snug on the 2 1/2" pipe.
Anyone?
gtc 01-16-2010 11:53 PM
Find someone near you with some leftover 2.5" SCAT aircraft ducting from their SSI installation. If that doesn't work, you can buy it online for about $8 per foot. I'm not really sure why pelican doesn't sell this stuff by now... people have been recommending it here for years.
Davie Boy 01-17-2010 04:22 PM
There you go! $8.25 a foot! You can't beat that!
Thank you.
ClickClickBoom 01-18-2010 11:55 AM
Here ya go:
SCEET AIRCRAFT DUCTING from Aircraft Spruce
eric
Drdogface 01-18-2010 12:04 PM
If you might prefer a different look you can get flex SS ducting from McMaster-Car. It's a bit tricky to work with but produces a nice result I think...
http://forums.pelicanparts.com/uploa...1263845041.jpg
Pazuzu 01-20-2010 07:35 AM
Originally Posted by ClickClickBoom (Post 5132681)
I know that everyone loves Aircraft Spruce, but it's SO EXPENSIVE!
Thermoid High-Temp Ducting - 600 Degree Aircraft Silicone Ducting
11 foot lengths, $75 shipped. It's the same 600 degree, double wrapped silicone 2.5 inch tubing. for heck of a lot less. This is enough for two cars doing a backdate, or one car replacing EVERYTHING.
bpu699 01-20-2010 08:13 AM
Cool find...
jtfreels 01-20-2010 11:56 AM
Yeah thanks for posting these, I too need to replace some heater hose.
But a question, why 600 degrees? Wouldn't the 350 degree rated work just as well, I mean my heat doesn't work THAT well. And I'm only refering to the hose inside the engine compartment.
Jay
Pazuzu 01-20-2010 12:14 PM
They have the lower level stuff too, but for a fraction more, why not get something that you'll never have to worry about? If you know that you're not going to change any that might be near the exhaust, then go with the black stuff, but once you get it home, you'll want to change everything out with nice fresh clean tubing ;)
PcarPhil 01-20-2010 12:57 PM
I've been wondering this myself. Specifically what temp rating is needed for the hoses that connect to the heat exchangers.
Is 350 degrees enough?
I've been using the SCAT tubing, with it's 550 degree rating, and it works great. I've been thinking about this for silicone connectors though...
Davie Boy 01-22-2010 05:48 PM
Just received and installed my Aircraft Spruce hose today. It was a perfect fit. I ordered just 1 foot at $8.25 plus shipping because that was the minimum, and I only needed enough for one side. But when I received it, I ended up with 18 inches. Pretty generous of them! Half of that was more than enough for my one side. Now I have enough for two!
Thanks for the responses, guys.
SP2 01-22-2010 06:18 PM
Just go to a small aircraft repair center. They will have aircraft SCAT tubing in any diameter. Bring an old tube if you don't know the size.
ntrylvl 01-22-2010 07:26 PM
Originally Posted by Davie Boy (Post 5141517)
Just received and installed my Aircraft Spruce hose today. It was a perfect fit. I ordered just 1 foot at $8.25 plus shipping because that was the minimum and I only needed enough for once side. But when I received it, I ended up with 18 inches. Pretty generous of them! Half of that was more than enough for my one side. Now I have enough for two!
Maybe you can loan me a few inches when I need to replace one of mine :D
Davie Boy 01-23-2010 10:31 AM
Of course, dude. I doubt I'll need the left-overs for quite some time. Hook you up.
