Recreational User
Davie Boy's Avatar
Need Hose: Heat Exchanger To Flapper Box
It looks like Pelican has an OEM hose for $27. Is that really what I gotta spend? Does anyone have something aftermarket and cheaper? Auto parts places carry "pre-heater" hoses that look perfect, but they don't carry anything larger than a 2" diameter. Home Depot and Lowes carry some similar 3" diameter hoses, but they fall apart when you try to get them snug on the 2 1/2" pipe.
Anyone?
'88 924S - Stone Grey Metallic
Old 01-16-2010, 08:04 PM
gtc gtc is offline
abides.
gtc's Avatar
Find someone near you with some leftover 2.5" SCAT aircraft ducting from their SSI installation. If that doesn't work, you can buy it online for about $8 per foot. I'm not really sure why pelican doesn't sell this stuff by now... people have been recommending it here for years.
Graham
1984 Carrera Targa
Old 01-16-2010, 11:53 PM
Recreational User
Davie Boy's Avatar
There you go! $8.25 a foot! You can't beat that!
Thank you.
Old 01-17-2010, 04:22 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Here ya go:
SCEET AIRCRAFT DUCTING from Aircraft Spruce
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 01-18-2010, 11:55 AM
Wandered off somewhere...
Drdogface's Avatar
If you might prefer a different look you can get flex SS ducting from McMaster-Car. It's a bit tricky to work with but produces a nice result I think...
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 01-18-2010, 12:04 PM
Originally Posted by ClickClickBoom View Post
I know that everyone loves Aircraft Spruce, but it's SO EXPENSIVE!
Thermoid High-Temp Ducting - 600 Degree Aircraft Silicone Ducting
11 foot lengths, $75 shipped. It's the same 600 degree, double wrapped silicone 2.5 inch tubing. for heck of a lot less. This is enough for two cars doing a backdate, or one car replacing EVERYTHING.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 01-20-2010, 07:35 AM
Cool find...
Old 01-20-2010, 08:13 AM
jtfreels's Avatar
Yeah thanks for posting these, I too need to replace some heater hose.
But a question, why 600 degrees? Wouldn't the 350 degree rated work just as well, I mean my heat doesn't work THAT well. And I'm only refering to the hose inside the engine compartment.
Jay
2002 Boxster Speed Yellow
Old 01-20-2010, 11:56 AM
They have the lower level stuff too, but for a fraction more, why not get something that you'll never have to worry about? If you know that you're not going to change any that might be near the exhaust, then go with the black stuff, but once you get it home, you'll want to change everything out with nice fresh clean tubing
Mike Bradshaw
Old 01-20-2010, 12:14 PM
I've been wondering this myself. Specifically what temp rating is needed for the hoses that connect to the heat exchangers.
Is 350 degrees enough?
I've been using the SCAT tubing, with it's 550 degree rating, and it works great. I've been thinking about this for silicone connectors though...
Old 01-20-2010, 12:57 PM
Recreational User
Davie Boy's Avatar
Just received and installed my Aircraft Spruce hose today. It was a perfect fit. I ordered just 1 foot at $8.25 plus shipping because that was the minimum, and I only needed enough for one side. But when I received it, I ended up with 18 inches. Pretty generous of them! Half of that was more than enough for my one side. Now I have enough for two!
Thanks for the responses, guys.
Old 01-22-2010, 05:48 PM
SP2 SP2 is offline
SP2's Avatar
Just go to a small aircraft repair center. They will have aircraft SCAT tubing in any diameter. Bring an old tube if you don't know the size.
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 01-22-2010, 06:18 PM
Stop fronting.
ntrylvl's Avatar
Send a message via AIM to ntrylvl Send a message via Skype™ to ntrylvl
Originally Posted by Davie Boy View Post
Just received and installed my Aircraft Spruce hose today. It was a perfect fit. I ordered just 1 foot at $8.25 plus shipping because that was the minimum and I only needed enough for once side. But when I received it, I ended up with 18 inches. Pretty generous of them! Half of that was more than enough for my one side. Now I have enough for two!
Maybe you can loan me a few inches when I need to replace one of mine
Chris Harrell
'72 914 1.7 Saturn Yellow, '73 911T-RS Coupe Red
Old 01-22-2010, 07:26 PM
Recreational User
Davie Boy's Avatar
Of course, dude. I doubt I'll need the left-overs for quite some time. Hook you up.
Old 01-23-2010, 10:31 AM
