poorshe911's Avatar
timing adjustment on a re-curved dist?
Hello everyone.
I have an '83 SC with a distributor that was re-curved some years back by the PO.
Does having a re-curved distributor mean your ignition timing adjustment is different than the manual procedure (5 deg BTDC with hoses off and plugged)?
The reason I'm asking is, I checked my timing and found it to be set at 10-15 deg BTDC. I adjusted it it back to 5 deg BTDC, the car runs great but I'm wondering if I should have left it alone because of the re-curve.
I thought the re-curve changed the slope as the engine rev's but have no clue if it's suppose to get set higher at idle.
Thanks for any help.
Old 08-08-2011, 07:45 PM
Max Sluiter
Flieger's Avatar
You should set the timing at 6000rpm and let the idle timing fall where it may. The timing at idle should be about the same with a re-curved distributor since it just changes when and how fast the advance comes in.
Old 08-08-2011, 09:31 PM
