Jupiter 911
bklyn's Avatar
Window switch
Just recieved my new window switch from our host, would it be best to remove the door panel or just pry out the old switch and replace? Thanks Lenny
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 01-22-2010, 03:20 PM
Oh Haha's Avatar
GENTLY pry the switch out and swap the wires one for one.
There is a thin metal surround around the opening sobesure that you pry only on the switch as it is easy to bend the metal which won't allow the switch to seat all the way.
Pacific Blue
Wayne
Old 01-22-2010, 03:25 PM
Jupiter 911
bklyn's Avatar
Thanks Wayne, sounds better then removing the panel right now.
Old 01-22-2010, 03:27 PM
Ruby911
ruby911's Avatar
+1 on carefully prying the switch out of the panel. I did it about 2 weeks ago and the whole job took about 3 minutes.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 01-22-2010, 03:36 PM
Jupiter 911
bklyn's Avatar
Great, will do that tomorrow.
Old 01-22-2010, 03:42 PM
nineball's Avatar
be warned it will be a different finish from the original, one is matte and one is gloss. if you are replacing one of the driver's side switches like i had to i found it best to replace the passenger side and use that one to replace the broken driver's side.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 01-22-2010, 10:11 PM
dshepp806's Avatar
+1
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-23-2010, 02:13 AM
Be very careful when pulling the old switch - the wires on mine were very short and I had to reach inside the panel with needle nose to pull the wires.
Also - one set of my wires were all black - I had to mark the wires as to which of the 5 tabs they went to so I could hook it back up properly.
'85 RoW 911 Coupe
'65 356 SC
'72 BMW 2002Tii
'10 Cayenne
'20 Ram Longhorn
Old 01-23-2010, 04:56 AM
