Best way to remove Injector connector?
Does anybody know a trick to removing the harness connector from the injectors?
I did this last year to do some work on the top end, but I don't know how I did it.:rolleyes: I'm talking about the C-shaped locking spring that retain the connector ears. Can't recall if I just pulled on them or what? I was trying to pull them to get'em tested and cleaned. signed, the slowest project do-er... |
Never mind - I finally got it - between my back and the confined space I was looking for a shortcut. I snuck in there with a jewelers screwdriver and slid each end of the spring clip out enough to free up the connector.
finished one side of the eng and called it quits for the evening. |
The wire retainer just pull off. Its the C2 you have to move the wire to release the connector.
Bruce |
| All times are GMT -8. The time now is 07:03 PM. |
