Best way to remove Injector connector?
Does anybody know a trick to removing the harness connector from the injectors?
I did this last year to do some work on the top end, but I don't know how I did it. ![]() I'm talking about the C-shaped locking spring that retain the connector ears. Can't recall if I just pulled on them or what? I was trying to pull them to get'em tested and cleaned. signed, the slowest project do-er...
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Never mind - I finally got it - between my back and the confined space I was looking for a shortcut. I snuck in there with a jewelers screwdriver and slid each end of the spring clip out enough to free up the connector.
finished one side of the eng and called it quits for the evening.
The wire retainer just pull off. Its the C2 you have to move the wire to release the connector.
Bruce |
