Hi all i am looking for some advice.i have a 1970's 911 it has a 2.7 liter engine.On a test drive last Saturday after a full engine re-build the crank shaft broke in 2 half's
![]() ![]() .Rather than going down the long road of another re-build I'm looking at dropping in a engine ready for road.i would like to put in a 3.2 liter is this a problem, i have one found engine, gearbox and ecu ,is this all i need for change over, do i need wiring loom or anything else to make the job straight forward![]() ![]() ![]()
You will need some odds and ends. Do a search on "Carrera engine swap".
Kurt |
