Purchased a '85 911 & have many, many questions
Hi,
1. I'll start at the beginning. I am trying to figure out where to place the jack and jack stands. I have checked the bentley manual and the picture is vague at best, it seems to indicate somewhere near the corner inside of the wheels. Seeing some damage where previous owners have got it wrong, I am wondering if someone can describe exactly where I should put the jack or even better a picture. 2. Need to change the oil. I have read the porsche approved oil bulletin, but it leaves many, many options. I have heard that synthetic oil in a car of this age is not the best idea as tends to finds leaks. Does not need to be the best of the best but I would like to reduce wear and treat the engine the best I can. Wondering if someone can suggest something they have used for years, that works well and takes a common sense approach to the matter. 3. Oil filters, haven't done much research here, but I checked at the local auto parts store and they carry a Baldwin filter for the car. I have used Baldwin filters in industrial applications as they come highly regarded, wondering if anyone has experience with them or can suggest something better. I feel a top quality filter is worth the money. 4. Transmission oil. As she's a bit challenged in the shifting department, I would like to get the best available. I have adjusted the linkage and will be replacing the bushings which will help, but I feel a good quality tranny oil is worth the investment. They have Royal Purple at the auto parts store, wondering if the same theory applies and a synthetic tranny oil will finds leaks there as well? Any suggestions? 5. Tires. There is a lot of information on this topic as well, however wondering if someone with experience can make a suggestion for me. I live in western Canada, do not drive it all year, but will certainly encounter rain at times. I use the car as a weekend / daily driver. No racing, but I do enjoy driving it and with more experience I will likely get a better sense of mine and the cars limits. I don't drive it too much so wear rate is not my first priority, although its not my last either. Again, I'm not looking for the best of the best and would like to keep the cost reasonable, but I would like a good tire. I figure I'm looking for something that's good at most things and likely most important has a gentle breakaway (to keep me out of trouble). It has stock Fuchs. Thank you to all that reply, your advice, suggestions and experience are much appreciated. So much to learn. Feds |
Wayne's 101 Projects Book is a must read. It covers proper jack points and lots of other "must know" stuff.
Engine Oil: I use Castrol 10-40w I live in AZ Tranny oil: Swepco 201 I strongly recommend Wayne's 101 Porsche Project book. Good luck and have fun, Ed Garcia 1977 Carrera 3.0 |
Cliff notes: Use 20W-50 or 15W-40. Good brands include Brad-Penn Racing, Vavlvoline VR-1, Kendall GT and SWEPCO 306. There are others. I'll let you read and learn. Quote:
So much to learn. Feds[/QUOTE] |
I'm sure you will get more detailed responses, but here's my take.
1. I place the jack directly on the engine case with just a wad of newspaper in between to protect metal-to-metal contact. The usual place for the stands is the rear torsion bar end caps. It has been done by many for years. It's okay. 2. The general preferred oil is Brad Penn Oil. You have to find a place that sells it, but it is a very popular choice around here. 3. The general preferred transmission oil is Swepco. It can be found on this site :) 4. Tires, I can't help you on. Sorry. I don't know enough about the subject myself. |
Oil: Royal Purple 10-40 works for my 3.2 though I will try Brad Penn at some point.
Filter: Mahle OC54 from the host should be good enough. |
most important - brake hoses & fluid
see the Long Term Maint. thread, active today |
You can use a filter from a Buick. Sorry but I can't remember the model,but they are identical.
101 projects from our host is a real good place to start, covers a lot of first timer info.
I use the Mahle oil filter and don't forget your fuel filter as well. I get mine from Pelican cause it is cheaper than local suppliers, I bought a stock air filter from a local supplier and it was almost $100.00 with taxes I use Swepco 201 for the tranny, our host supplies it. I'm not an expert but there are lots of guys with tons of knowledge on this board and the great thing is they don't mind sharing the knowledge, unlike any board I've ever surfed. Welcome and post some pic's when you get some, the search is a good thing too, or so I'm told but I can't get it to work |
I have been uising Wix brand filters ever since Charles Navarro did extensive research and posted results. My local O'Reilly's carries them for the 911.
Tires -
I am running yokohama s.drives on 7&8 inch Fuchs. Given the price, I really like them. Good in the wet weather, relatively quiet, and stick pretty good. Breakaway is very predictable, even in the wet. Tires with a rounder shoulder typically have better smoother breakaway characteristics, but who knows. Its a summer tires though. Probably not too great once in the 30's (F). Ride is also nice, but I came from old goodyear f1s on 18's (way too big imho). My only issue is that the rim saver makes the tire look really chunky, especially the front mounted on 7" fuchs. Its also not the lightest tire by a pound or two. |
If I'm lifting one side of the car only, It's really convenient to use a "jack pad" inserted into the jack lifting points under the running boards. The jack pad is a metal bar which inserts into the jack point to which is welded a round lifting point. You use a floor jack to jack the side with... very convenient.
Thanks everyone, I will be ordering the 101 projects book immediately along with the other items I have determined I need.
Being in small town Canada, Swepco is nearly impossible to find and no body has heard of Brad Penn Racing oil and I'm a little leary of the shipping costs, so I am still working my oil choice. A couple other questions though, someone suggested brake fluid and lines, which is likely a very good idea. When searching the host site, they have OEM lines and braided lines. The braided lines appear to be better, but they are also cheaper than the OEM ones. Cheaper and better do not usually come together, wondering if anyone would suggest one over the other? Also, from reviewing the Tire Rack website, looks like my main tire choices are Pirelli P6000 OEM (I believe) and Sumitomo HTR 200, wondering if anyone has any thoughts on these? it also sounds as though yokohama's are an option as well, they didn't seem to come up, but I'll do some more research on them. Thanks again. |
come on this guys asking for help not to save $1.44 But before i bust on your b@lls to much I will ask you this , 1--WHY would you ? 2--Do you really ? or are you being funny? 3-- If you do , please re read #1 . Unless you inherited 4 cases of filters from an uncle and they fit a Buick that he had and you can't remember what model , but even if thats so please re-read #1. |
For the Transmission get a non-synthetic 75W-90 GL-5 Gear oil. A decent auto parts store will have one or can get one for you. Kendall and Valvoline both offer a good product. For motor oil, if you want a 20W-50 look for Valvoline VR-1, Total (used to be ELF) or Kendall GT oil. Royal purple is also ok but more expoensive. Your best bet is to get a Product data sheet on the oils offered in your area and look for ones with Zinc and Phosphorus content over 1100 ppm (0.11%). Get a good quality brake fluid. If you have import or speed shop nearby, see if you can get ATE Blue or ATE 200. Both are DOT4 with very high wet and dry boiling points. Here in the states it costs about $10/liter. As far as brake lines, the braided ones are ok but for me anyway, I use the factory rubber braided ones. Why? The service life of an OEM one is about 10-15 years and they do not have the catastrophic failures associated with the braided lines. If you go the braided route, be sure you insepct them every year. There should be more tires than that for you. I suspect you are looking at only OEM Sizes. You can go a bit wider with no penalty. Ask around what others are using for your year and wheels. To determine which sizes have the same rolling diameter (this is what affects the accuracy of your speedomter and odometer), use this calculator: Tire size calculator. |
I try to buy most things from PP, after all, they sponsor this site. I buy a number of things at one time to get the free shipping, or at least better shipping rates for my buck.
Feds, post your 1st name at your signature, and where you are located. Also, for the 915 the bushing replacement kit is well worth the money. A very big improvement in shifting. Read 101 projects by Wayne. Its well detailed. The only disagreement I've found with his book is in the oil tube replacement section. Wayne says to coat the O-rings with a little oil to ease their sliding. Silicone grease is the ticket. Welcome. |
With the availability of 911 filters either factory or aftermarket options I just do not see the revelence in recommending to a Newb(no offense) to start looking into "crossover parts" and i now I don't recommend a fram filter for the 911 although I am sure there product is fine I just cant see reason to look for a filter for a 911 and then find it only to decide that the filter fitment guide says this other number fits a Buick grandcrap I think I'll try to shove it on my Porsche and see if it fits .......may be it just me but if its made to go on a Buick it stays on a Buick and i doubt a fram filter for a Buick is going to make the 911 more bullet proof. i could see if your filter BLEW UP in a parking lot and the only filter you could find had metric thread and was smaller dia and would seal to get you home or the next shop but I would not come out to the world and say that I had found a way to save a dollar by putting the wrong part on my car. I am sure you "COULD" put American racing rimz with a Chevy bolt pattern on your car if you jerry rig your hubs and I am sure you could fab a set of bush-wacker flares on the rear but youd look like an ssa if you posted your new bushwacker flair factory approved turbo super wide body kit on this board or any other ........... Just think about it .................................................. ...............:eek: |
Feds:
First and foremost, welcome to the Best Porsche Forum on the Internet! Second, since I live in a very cold climate, during the Winter months I run Mobil 1 Syn. 10W-30 High Mileage in all my Porsches. Then, during the late Spring I change over to Mobil 1 Syn. 15W-50. I am no expert, but I have gotten very good results doing this for both the 911 and the 944. Brad Penn oil is the best, but I like you cannot afford the shipping cost. However, with that said, there are some people who "pool" their money to make a large purchase and then divide-up at delivery...seems like a good idea. Third, don't buy cheap products for your Porsche. Spend the extra ca$h for these German masterpieces and your car will thank you with longevity. Our gracious host sells everything you need right here on this site and the pricing is very, very competitive. AND, the shipping is FAST, FAST, FAST!! Fourth, SWEPCO for the tranny. Like others here have mentioned, Wayne's book is the best for working on your Porsche 911. The Bentley manual, the Porsche Factory Manual set, and if you can find a owner's manual for your year and it will help explain lots of stuff you need to know to keep your car in good shape. Once again, "Welcome" and have fun learning about your Porsche. |
Hi SmileWavy
living in a small town of italian Alps I found "101 projects" used in Abebooks Here I found another for you: 101 projects for your Porsche - AbeBooks Ciao: Paolo |
thats more than a new one will run you from here if the exchange rate is near where i think it is ..................
Porsche 911 & Turbo CIS Fuel Injection - Page 19 $22.95 us + shipping and your buying it from the man that wrote it . |
Thanks to all that made suggestions. To put any concerns to rest, I have ordered 101 projects, swepco for the tranny and a couple mahle filters (among many other good things I found on the website) to get me started. Although I appreciate all the advice, I tend to agree that its worth a couple extra bucks for a product that was designed for the specific application.
I'm sure I will have many more questions to come. I thank everyone very much. It's truly remarkable that one can pose a question and in a matter of minutes have such excellent expertise available. For any that are interested in the car. I bought it last summer from a guy who said it was a european car, but has turned out to be from japan, which I believe means the low compression engine although I'm rather fond of the seats. The serial numbers clearly indicate north american cars, but when the serial number came up ROW I assumed he was right. After many years of reading porsche magazines and thought I new all I needed to make a purchase, hmmm how does that saying go, unconsciously incompetent. I was originally looking for a 944 s2 or turbo as I figured that was the best value in my budget, but when I came across the opportunity to purchase a 911 in my budget I leap right in, eyes wide shut. Not a bad car but certainly will need some freshening to get it where it should be and after it was repainted, who ever put it back together seemed to do a pretty quick job of it, headlights not aimed correctly, the odd bolt missing.... 90,000km's on the odometer although I am somewhat curious if that's really the case. Doesn't seem to burn oil compared to what I hear these cars can and runs smoothly, starts well. I think it's biggest issue is lack of use. Sure is an enjoyable car to drive though. I will post I picture when I figure out how to do such a thing. Take care all, talk to you soon and thanks again. |
Hey Feds mine also is a Jap spec 911; similar mileage but I suspect an ex garage queen. Engine totally rebuilt in Japan after pulled stud episode. If you pull your speedometer out you can check if the factory paint still covers the bolts holding the case together. though I suppose this doesn't exclude someone replacing old with newer , or faking factory paint.
I too like the upholstery ; though tartan in Japan???- I guess weirdly exotic . btw to post a pic just scroll down the reply screen and click upload photo eg from your desktop. |
From another thread, a chart to help you select the proper oil weight. Note that 10W-30 is only for the coldest of climates or for "fuel efficient oil" but Porsche goes on to say, don;t do that without being very careful first. Quote:
I spoke with a local "performance expert" today who said get a decent oil and then recommended an oil additive, either "nitro boost" or another product from lucas oil products (can't rememeber the name). His argument was, get a reasonable oil and then add a good additive and you're better off. Not sure which argument is better for my 3.2, get the BEST oil and then you don't need an additive OR get a good oil and then add an additive? Have any of you guys ever used any of these additives? do they have any long term negative effects? any thoughts?
Thanks again |
It is my understanding that the Lucas oil additives do not address the extreme pressure lubrication issues, they modify the oil viscosity. If you want to go with a 15W-40, Delo 400LE has "the good stuff" right out of the bottle. I cannot find the data, but I would suspect that Shell Rotella would be similar but I could not find the Zn and P nimbers on their web site. The risk of not providing adequate protection would be expected to be premature failure of cam shafts. |
Feds,
To resolve your oil selection problems, go take a look at what is available at your Friendly Local Auto Parts Stors (FLAPS). Then go to the web and look up the manufactureres PROUDCT DATA SHEETS. Find the ones with a high (greater than 0.1% or 1100 ppm) zinc and phosphrus content. Those are the ones you want. |
Hey Harry:
Thanks for the information with regard to Mobil 1 syn! I did not know that the ZDDPlevels are not acceptable. That is NOT good. As far as the chart from the owner's manual, that looks just like my owner's manual for the 1983 MY. In fact, that is why I chose to run in the Winter with a different grade. I do seem to get better performance out of the 15W-50 most of the year. This year, here in Eastern Washington, we have had dry days with very, very cold nights and low temps for the day on average. So, it seemed like the best decision for my daily driver 944, but certainly may not be right for the 911. I have been driving the 911 to keep the battery charged and burn some carbon, but only this year since there is no salt or snow on the roads. I never drive it otherwise in Winter months. Appreciate the info. Time for me to read up on the additives too.SmileWavy Once again, "Thanks!" |
I guess my real message is that we do no know what levels of ZDDP are in Mobil 1 products as they choose not to publish it in their Product Data Sheets. Now I know Mobil includes this information in their marketing materials but, as an engineer, believe the Product Data sheets get a higher level of review for absolute accuracy. If you read the very long Ultimate Oil Thread, you will find out that the lower levels of ZDDP are not required in the heavier oils. But then again, the heavier oils are not required to keep higher levels of ZDDP. So it is up to us to determeine which ones have acceptable levels. Hence my reluctance to be confident. |
New that we all have that out of the way, are there any more questions about the 1985 car, what to do to it, and how?
FWIW, I've heard very good things about the Wix brand oil filters from many very reputable people. Even though I've been using the Mahle brand, I would be comfortable using the Wix as well.
But if filter # xyz-3 application guide state fitment in a P911 and you cross it and it shows that a #xyz-3 fits a buick g, why wouldn"t you tell the guy asking about a filter for his P911 to get a #xyz-3 rather than tell him to go and look up a filter for a buick g.
While searching to see what tires would be best, the tire rack says that the original tire size for a '85 911 is 195/65-15 and 215/60-15. My tires are 205/55-16 and 225/50-16 mounted on what appear to be fuchs. First off, can anyone confirm if the tire racks size is the correct original? if so, this means someone swapped them for 16's at some time. Is there a simple way to tell if the are original fuchs? the tires that are on their seem to work fine, so barring any concern I'm figuring on relacing them with the same size.
I have wondered about the odometer ready, as it seems to be adding up miles quicker than I figure it should. Given the difference from stock, it will be out of calibration. I thought is if I figure out the diameter of the stock wheel, figure out the diameter of my wheels and divide the stock size by the difference I should come up how much it is out of calibration, does this sound correct? Given that stock is 15's and these are 16's I would think it adding miles slower than actual but I'll crunch the numbers and see what I come up with. Lastly, I'm sure these topics have been discussed before. Can anyone tell me how to search the message board to find out what threads this topic may have been discussed in? Thanks again. |
Ulitmately it's your money, your car, your choice. I, personally will not look to save a few $$ on a non-OEM filter after hearing Mr Steve Weiner observations below. He has seen more damaged engines/cars than I ever will. Quote:
In answer to your other question about the odometer, if you have a 16, and used to have a 15, then your odometer is actually turning slower. If the axle makes 1 revolution, your 16 inch wheel actually travelled farther, but your odometer doesnt know that. I always have trouble mentally figuring that out in my head. If you had 10 inch wheels, you would go down a side street and the speedometer would register a much higher number. i could be wrong, but thats how I see it Lastly, in the bar right under your screenname on the right hand side is a search button. You can search in any particular forum, such as engine rebuild, turboing, or tech forum. The search field should state what you are looking for, and try not to use numbers. It doesnt like them. I always have trouble searching, but if you ask nicely, most regulars who have been here a long time will respond with more information than you were hoping for. They are good |
Check my earlier post #14, it gives you a link to a tire size calculator that allows you to compare tires and it's impact on odometer/speedometer readings. Quote:
