Help id this tranny
Help id this tranny
-------------------------------------------------------------------------------- I have a transmission that has the case part numbers 930 301 101, 102, and 103 I can't find any other ledgible identifying numbers at all. There is a 10 75 under the case number on the main housing. I wonder if it's a really early 930 trans. Anyone know what this is? I asked on the 930 side, got no help there. Appreciate any help I can get! Drew |
Drew,
Post some images. That will tell the general transmission Type. Those are casting numbers and date code cast into the side of the castings. The important numbers are (were) on the support for the clutch cable. There should be numbers like 777xxxx and 930/33. Perhaps a ‘12’ in between. After making a nice and well protected boss for these important numbers in late ’71 type 911 transmissions, Porsche AG chose to put the numbers in the most vulnerable place possible. Shame on those who made that decision. There are some ‘crime scene’ techniques that can raise the numbers scraped off. Best Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
pictures
Yea, you're...I don't know what I was thinking. I took the pictures then forgot about them. Here you go. Does this help?
This is a 1975-77 early short bellhousing 930 4 speed trans Drew !
Nice catch... |
Thanks Jim. That's what I was hoping. Ill put it to good use.
