Eye of the Toiger
matty74's Avatar
Can a 964 super Sport Camshaft be used with CIS and/or Motronic?
What kind of performance increase would one get??
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 01-25-2010, 02:25 PM
Bill Verburg's Avatar
yes, somewhat south of 300hp on an otherwise stock 3.6 w/ headers and chip designed for it.
Bill Verburg
Old 01-25-2010, 02:32 PM
grateful user
don gilbert's Avatar
what are the specs on a 964 "super sport cam" (all cars from 84 up are motronic, 964's to) Is it a special grind from other 964 cams?
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 01-25-2010, 02:33 PM
964 versions will be the same or similar
Bill Verburg
Old 01-25-2010, 02:42 PM
rgoodrich's Avatar
Do you plan to use them on a 3.0 or a 3.6?
Old 01-25-2010, 03:24 PM
Eye of the Toiger
matty74's Avatar
Either a 3.0 or 3.2
Old 01-25-2010, 03:25 PM
richemj's Avatar
I'm running John Dougherty's DC21 racing profile "Sport 964" cams on my 3.2 (Motronic) and together with a Steve Wong chip, bored throttle body, and headers....pulls hard through 7k! @275HP!
Dougherty Racing Cams
Highly recommended!
-Mike
'71 RS LWT 3.2L
Old 01-25-2010, 04:55 PM
camgrinder's Avatar
Here is some dyno results on a set of 993SS cams I made. 248/234 @ 1mm, .490"/.455" lift on 114 lobe centers. 3.2 litre, 10.5-1 cr, tuned motronic with headers. Only change was the camshafts. Customer wanted a higher HP peak without losing much mid range torque.
John Dougherty
Old 01-28-2010, 10:43 PM
