-   -   Yawn… Yet another 911R Clone build thread… (http://forums.pelicanparts.com/porsche-911-technical-forum/523666-yawn-yet-another-911r-clone-build-thread.html)
Matthew Barnes 08-11-2014 12:47 AM
I am so jealous of your solid shell, painted.
Feels so far away.
Love the colour.
R_Builder 10-02-2014 08:49 PM
Man that was a lot of work...
Tough to say whether the electrical work or the fuel lines took longer, but I do know the fuel system was not cheap! All aluminum lines and AN-6 fittings.
The rear end is now ready for the powertrain... everything that can/should be done is buttoned up. The cam sync sensor wiring and injector harness wires have to wait and can be seen in the front left corner of the engine bay. All the other sensor wiring is harnessed and ready to plug in:
http://forums.pelicanparts.com/uploa...1412307607.jpg
http://forums.pelicanparts.com/uploa...1412307624.jpg
http://forums.pelicanparts.com/uploa...1412307637.jpg
http://forums.pelicanparts.com/uploa...1412307651.jpg
Once I get front suspension parts back from the powder coater's, I can get the car on all fours and proceed with the nuptials!
rennch 10-02-2014 09:19 PM
Mmmm, I've missed this! Looks like I'm just arriving at the punchline.
toddu 10-03-2014 04:01 AM
What hose are you using from tank to catch can? I can't find one that flexible.
Todd
R_Builder 10-04-2014 08:22 AM
Todd
That is a factory hose... 911-107-393-01... the one that breathes the oil tank to the right side of an early CIS airbox. I think I was able to get the original version (911-107-393-00) when I first set this up way back when. It worked unmodified, I suspect the -01 could do the same.
Hope that helps,
R_Builder 11-30-2014 07:38 PM
The happy couple...
Got the powertrain in about a month ago! Enjoy the pics, you know the drill...
http://forums.pelicanparts.com/uploa...1417404990.jpg
http://forums.pelicanparts.com/uploa...1417405006.jpg
http://forums.pelicanparts.com/uploa...1417405028.jpg
Always surprised it actually can fit. Nice to have some more floor space in the shop!
R_Builder 11-30-2014 08:00 PM
One month into it and still connecting the dots
Mechanicals have gone well save one snag on the front oil cooler stuff. Put that on the back burner and focusing on the top side engine bay electrical. I did so much prior to engine install, have done a bunch more now that the motor is in, and STILL have a bunch to go :(! Don't take this EFI thing lightly if you jump off the bridge... it is a lot of work. Gotta be patient!
Pretty hard to tell by the pictures, but I am down to the cam sync sensor run, shortening the O2 sensor lead, and building the fuel injector harness:
http://forums.pelicanparts.com/uploa...1417405932.jpg
http://forums.pelicanparts.com/uploa...1417405956.jpg
http://forums.pelicanparts.com/uploa...1417405991.jpg
http://forums.pelicanparts.com/uploa...1417406018.jpg
http://forums.pelicanparts.com/uploa...1417406049.jpg
http://forums.pelicanparts.com/uploa...1417406076.jpg
The fuel system is finally done (thanks Len) and Mr. Clewett is helping me avoid the land mines. They are two patient guys.
Thanks for following along... SmileWavy
R_Builder 02-02-2015 09:05 PM
Signs of Life...
It took most of December to get all the engine wiring finished up. Finally, finally time to install the battery and see how things look.
Been here before, but always nice to see lights:
http://forums.pelicanparts.com/uploa...1422938607.jpg
But this is new territory:
http://forums.pelicanparts.com/uploa...1422938647.jpg
Good news is all the EFI sensors were alive and well!
Big hurdle cleared so onto the next. Fuel system checkout. Gas guage/sender still works right:
http://forums.pelicanparts.com/uploa...1422938946.jpg
Trying to avert a mess/just in case:
http://forums.pelicanparts.com/uploa...1422938997.jpg
http://forums.pelicanparts.com/uploa...1422939010.jpg
http://forums.pelicanparts.com/uploa...1422939024.jpg
I already knew the fuel pump wiring was all correct, so just gotta turn the key and hope for the best :rolleyes:...
RESULTS: Only one tiny leak presented itself, but was easily fixed. What a relief! LOTS of custom work required just to see this number register on the gauge:
http://forums.pelicanparts.com/uploa...1422939338.jpg
Not too much left on the pre-start to-do list....
R_Builder 02-04-2015 09:22 PM
Fired right up...
It's alive and well! I took a video, but no way to post it, so a blurry fan picture will have to do:
http://forums.pelicanparts.com/uploa...1423113163.jpg
No real drama to speak of, which of course is a good thing when you run a new motor for the first time. No leaks to report after the 20 minute run-in. Awesome to see the gauges doing their thing:
http://forums.pelicanparts.com/uploa...1423113380.jpg
There will be plenty of EFI tuning to do later, but for now I had to dump the oil. I already can't wait to hear that R muffler again and rev it a little more. All the parts are finally in hand to complete the front oil cooler setup, so that is the next big item on the to-do list...
porsche boy 02-04-2015 09:47 PM
As I read this, I am smiling from ear to ear. What a great story. WELL DONE !!!!
merbesfield 02-05-2015 05:10 AM
Awesome on the starting. 👏 Is that fuel line across the motor staying as is?
scotiagreg 02-05-2015 10:52 AM
Looking great Doug! It won't be long now before she's roadworthy. I put over 5000kms (3000miles) on my 68 this summer with nary a hiccup. Sooo much fun to drive !!
R_Builder 02-05-2015 11:54 AM
fuel line
Originally Posted by merbesfield (Post 8471974)
Awesome on the starting. �� Is that fuel line across the motor staying as is?
Well, I am on the fence about it. I decided to make that line myself because I had everything I needed from the rest of the fuel system build. I did NOT want a big braided line with 90 degree end fittings across there, mostly due to looks (wanted something cleaner). The 5052 aluminum line I made is nice and stiff because of the hump in it to clear the fan housing. I might clamp it to the shroud studs anyway.
Another option I thought about was to have Len make me a rubber line with 90's on the ends and clamp it to the top of the fan shroud at the 2 studs.
Thoughts/concerns?
R_Builder 02-05-2015 11:56 AM
Thanks Greg. Putting in the time and counting the days. Glad you are so happy with yours... it turned out great.
TRE Cup 02-05-2015 04:37 PM
ok- looking pretty nice Doug !
regarding the aluminum line: It looks nice, but there is no give going point to point solid tubing. I would prefer to see at least one end with a fuel rated piece of hose between the carb and the line. also if you fasten it to the shroud, let it float in the locating clamps.
The constant expansion and contraction, of the solid tube is a recipe for a failure in the future. Full on race cars, that use solid tubing are always being taken apart and inspected, so you can't use those as examples to follow
APachon71RN 02-05-2015 04:55 PM
Will the hinges clear the filter stacks?
~Andy
TRE Cup 02-05-2015 05:24 PM
R hinges are external on Doug's car. See pics below of other R's. Besides that if Doug was using stock hinges, those would clear the PMO air cleaners too
http://forums.pelicanparts.com/uploa...1423185854.jpg
http://forums.pelicanparts.com/uploa...1423185871.jpg
R_Builder 02-05-2015 09:30 PM
Thank you Dave. That is the issue that had me on the fence. In the long run I was leaning towards a custom E-85 rated high pressure hose from Len with 2 Adel clamps on the fan housing studs acting as guides only. I spent so much time/energy/money on the fuel system I just wanted to get on with it!
Can you believe it... it is finally getting close! You have been along on the ride from almost the beginning and it is much appreciated!!!!
Jonny042 02-06-2015 05:42 AM
I like the line - a nice touch. Definitely needs some clamps, and the point on vibration/cracking is valid. As long as it's well supported and not under stress (ie do the ends align perfectly with the fuel rails) I think it would be ok.
Nice job on the car!!!
R_Builder 05-07-2015 03:16 PM
Time for some updates…
February turned out to be front oil cooler install month for me. Pretty much all factory SC/Carrera vintage parts except for Chuck’s high clearance lines in the back and some custom bracket work up front. Always “fun” to do this on a car that has never had a front cooler :rolleyes:. This install put up more of a fight than usual because of parts availability issues, fitment issues with my chassis, items damaged in shipping, undercoating touch ups, fender painting, blah blah blah. Very glad it was finished and pleased with the results! A lot of us have been to this rodeo before so I’ll just show you the answer (from front to back):
http://forums.pelicanparts.com/uploa...1431036732.jpg
http://forums.pelicanparts.com/uploa...1431036743.jpg
http://forums.pelicanparts.com/uploa...1431036751.jpg
http://forums.pelicanparts.com/uploa...1431036761.jpg
http://forums.pelicanparts.com/uploa...1431036775.jpg
http://forums.pelicanparts.com/uploa...1431036788.jpg
http://forums.pelicanparts.com/uploa...1431036799.jpg
http://forums.pelicanparts.com/uploa...1431036808.jpg
Love that last picture. Seems like they were designed to fit there...
