Windshield Install
But had to deal with my dash top first. The original pressboard dash piece I had was in decent shape but shrank too much with age to fit well, so I decided to make a new one out of fiberglass. Too bad I had already wrapped the pressboard version in new vinyl :rolleyes:. So, rough cut to shape:
http://forums.pelicanparts.com/uploa...1446174929.jpg Lots of back and forth fitting and trimming, then finally drilled the holes and fit it with the plastic pins: http://forums.pelicanparts.com/uploa...1446175022.jpg 4 hours to get to that stage but very good results. I was able to get the vinyl off the pressboard and onto the fiberglass with the help of all those binder clips I seem to have laying around now. It was like headliner work all over again: http://forums.pelicanparts.com/uploa...1446175236.jpg And installed: http://forums.pelicanparts.com/uploa...1446175263.jpg http://forums.pelicanparts.com/uploa...1446175281.jpg The windshield was all set to go with a factory seal and new trim, so after a couple false starts my son and I got it installed for good without too much drama. http://forums.pelicanparts.com/uploa...1446175505.jpg Sweeeet!!! |
Great work and great job narrating. Thx for the show.
Where did you source the sheet of fiberglass? How thick was it? |
It is about 1/8" thick (12 plies)... |
Looking really good Doug. You two did a great job on the headliner.
Forgot the decklid pics...
Rear decklid is on for real now. Wired in and lights work. I am using a factory latch/release setup for "security" and a clean look:
http://forums.pelicanparts.com/uploa...1446394308.jpg http://forums.pelicanparts.com/uploa...1446394635.jpg Now I just need to get that darn rear bumper back on so I can final fit the rear tail light housings to complete the back end... |
But before I do that...
I am continuing with the interior work. I am not a big fan of the '68 break away interior rear view mirror, so early on I decided to go with a '65-'67 chrome mirror, which would require me to make an adapter plate. All good, except I forgot to do that before the headliner install! I am a little bummed about this as I missed the opportunity to hide it, but it is not too visible when all is said and done and I took the time to finish it off nicely:
http://forums.pelicanparts.com/uploa...1446395209.jpg http://forums.pelicanparts.com/uploa...1446395224.jpg http://forums.pelicanparts.com/uploa...1446395242.jpg http://forums.pelicanparts.com/uploa...1446395257.jpg That last shot is hard fought. You would think that installing the sun visors would be quick and easy, but anything that has me working with the fresh headliner is kind of tedious. But that should be the last time, so I am grateful for no slip ups! If the exposed mirror adapter ends up bugging me, I didn't do anything to the headliner that would preclude me from going back to the '68 style mirror. Guess it can just be a conversation piece for those that look real close... One more thing to take care of in the interior, then it will be time for carpet install. |
R_Builder
Really enjoying following this project. I can be a bit OCD and perseverate details, so in regards to your headliner/rear view adapter conundrum I think it adds to the purpose-driven aesthetic of the R. Of course, not my car but just wanted to let you know that another guy out there who sweats similar issues thinks it fits the look. |
To further my point, the engineers could have likely found a way in which to hide the rear deck lid hinges whilst still allowing the lid to fully open. In the end, they sit atop the lid...and, come to think of it, have a similar look to your rear view adapter.
Soundproofed the rear seat area
Carpeting process is moving along nicely (but no pics to share yet). First step was to put a little soundproofing in the rear seat/parcel shelf area. This is the 1/8” thick, adhesive-backed stuff from Aircraft Spruce. Not too much to it but to do it:
http://forums.pelicanparts.com/uploa...1450544810.jpg http://forums.pelicanparts.com/uploa...1450544828.jpg This is all it will get. Not planning any science projects here. I guess I can always go back and add stuff to the floors pretty easily if need be, but that would be a different product for sure. Weird to see it all get covered up after so long.... |
My 1970 MG Midget (I know, not the same type of engineering - but with the same wobble) made every headlight in the rear-view mirror look like the headlights were making circles. I made a rubber gasket the shape of the mirror mounting to absorb the vibration, and the world was stabilized. Try it, it just takes some material with the ability to have some cushioning.
Well… the carpet is in!
See:
http://forums.pelicanparts.com/uploa...1453697822.jpg Oh wait, you probably don’t really want to see all the scraps :p! How ‘bout this instead? http://forums.pelicanparts.com/uploa...1453697886.jpg http://forums.pelicanparts.com/uploa...1453697897.jpg http://forums.pelicanparts.com/uploa...1453697909.jpg http://forums.pelicanparts.com/uploa...1453697920.jpg I used 3M spray 90 just about everywhere, but the floormats are just sitting in place for now. Just like the headliner, I must give most of credit to the wife for helping to make the carpet install successful. We make a good team on these types of jobs... As you can see, there is more progress than just carpet since it all needed to be worked together. Roll bar went in finally (bought it from TRE a loooong time ago), everything around the pedals is closed out, the engine ECU is mounted for good, shifter and p-brake are in (with heater wire and handle throttle hooked up), seat brackets installed, and… sills/thresholds closed out: http://forums.pelicanparts.com/uploa...1453697961.jpg I will probably spend a little more time fussing with the sills and lower door jamb areas to get the vinyl wraps and carpet strips looking better, but they are good for now. Guess it is about time for some chairs, eh? If you look close, you can see that I have also started in on the last big assembly step… the doors. Lots of parts involved there, with fit checks, more upholstery work, seals galore, and fiddling with the door frames. More on all that stuff next time. Take care, |
Long overdue update...
As always, time flies.. but slow and steady progress this year. Looking back in my pictures, it looks like I moved back to the rear to rehang the bumper for good:
http://forums.pelicanparts.com/uploa...1473553067.jpg Then back up to the front to truly get the headlight buckets ready for the H4's (lots of trimming for a good fit, lower brackets, drains, safety zip-ties, etc.): http://forums.pelicanparts.com/uploa...1473553129.jpg http://forums.pelicanparts.com/uploa...1473553143.jpg Then it was back to the doors. Finally got to hang these gems and install the roll up windows: http://forums.pelicanparts.com/uploa...1473553278.jpg http://forums.pelicanparts.com/uploa...1473553326.jpg Like I have mentioned before, there is a lot of time spent getting all the door stuff working right and all the seals in place. But in the end, you finally get to put these on :D: http://forums.pelicanparts.com/uploa...1473553463.jpg The outer trim and window swiper finish off the outside, and the car is finally all tight: http://forums.pelicanparts.com/uploa...1473553753.jpg Took a little while to get up the nerve to drill into the door frames for the updated wind blocks, but all turned out just fine: http://forums.pelicanparts.com/uploa...1473553854.jpg The proverbial light(s) at the end of the tunnel: http://forums.pelicanparts.com/uploa...1473553925.jpg |
What is this? Tim |
Everything is so well done..... Really love the fuel lines, what kind are they?
awesome! thanks for sharing!
"wind blocks" from our host's catalog: http://forums.pelicanparts.com/uploa...1473819741.jpg They close up the gaps between the door shell sheetmetal and the window frames at the front and rear. Just something from the later cars that will work on the earlier cars... |
| All times are GMT -8. The time now is 11:53 PM. |
