Rear caliper rebuild
Hi,
I'm rebuilding the rear calipers of my 1982 SC with Stainless pistons.
For the front calipers, I have a drawing in the Bentley manual where I can see how to install the pistons to get the correct 20° angle.
I found no instructions for the rear calipers.
How should I install the pistons to get the correct 20° angle on the cut out?
Thanks.
André
Old 01-28-2010, 01:06 PM
I just "eyeballed" them. You can get within 5 degrees or so with just your eyes.
-Andy
Old 01-28-2010, 04:59 PM
Max Sluiter
Flieger's Avatar
Do a search on the forum for 20 degree tool or something like that.
Basically, you get a sheet of carboard and a protractor then trace a 20 degree angle with a pencil and cut it out using scissors. And there you go...
Old 01-28-2010, 05:51 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Porsche Crest This one is good...
André
Check the Photos and Sktech in entry # 3 of this thread... 1988 911 Brake Caliper Rebuild Confusion
Salut
J.J.
Who Will Live... Will See
Old 01-28-2010, 06:04 PM
Hi,
Thanks for the replies.
Because English is not my native language, my question was not very clear.
I know how to fabricate and use the 20° template for the front brakes, but what to do for the rear brakes?
Should I just follow the direction on rotation, and where the disc enters the caliper, position the piston in the 20° position?
Or is it different?
Thanks,
André
Old 01-29-2010, 08:42 AM
Correct.
Tony G
2000 Boxster S
Old 01-29-2010, 08:53 AM
Somatic Negative Optimist
Gunter's Avatar
Andre,
Are the calipers ATE or GIRLING?
ATE promotes the 20 deg set-up but I think GIRLING does not?
It also depends on the position of the caliper vs. rotation of the disc.
The 20 deg setting is intended to counter-act the clamping-force wanting to distort the pads into uneven wear.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-29-2010, 09:15 AM
Hi,
My calipers are ATE.
Think I got the information I was looking for.
Tomorrow morning (in a few hours here in europe)it is rebuilding time.
Thanks a lot.
Regards,
André
Old 01-29-2010, 04:02 PM
JJ 911SC's Avatar
Porsche Crest Bonne Chance
Dédé
Keep us posted.
I order all the parts but Im a bit "gun shy" (pas trop sure de mes competence) to start the job.
Salut
J.J.
Old 01-29-2010, 04:59 PM
