911 915 Transmission type??
I have a '72 911 that I can't locate the transmission type in it. It was originally a sportomatic but was converted to a 915 transmission I believe, but no necessarily to a '72 915 (ie, 915/12). On the bottom of the trans I locate a part number 715-3385. There are several models of the 915 trans - where on the trans do I locate the 915 model number?? Anyone have a picture of where it is on the transmission??
If I end up needing to rebuild/replace this trans, which model of the 915 is best?
Old 02-21-2010, 10:35 AM
Peter Zimmermann's Avatar
Re: 7153385
"7" = Trans for 6 cyl engine
"1" = 5 speed Type 915/40
"5" = 1975
"3385" = consecutive build number
The model number is found on the same raised surface as the number you posted. Often that number has been ground down.
Keep the Shiny Side UP!
Pete Z.
Old 02-21-2010, 01:20 PM
