Send a message via AIM to Adidas
Heat Exchangers Question (2 pictures)
I've got an 83 3.0 911 with the later style thick flanged heat exchangers. Pictures below in first reply (picture1) Can an early 74 style thin flange heat exchanger mate up as well? The exhaust pipe on these units extends up above the top of the mating flange and actually seats inside the exhaust port of the head (picture2). Will a thin flange with a flat top seal properly? Any other options? Thanks.
Old 11-09-2010, 12:57 PM
2 pictures here.
Old 11-09-2010, 01:07 PM
Senior Advisor
James Brown's Avatar
For the most part, they will fit, bolt pattern same, but needs fitting parts like spacers and gaskets, and if early, oil lines are necessary. But why? Not much increase in performance if using small, old stock exchangers.
08 Cayenne Turbo
Old 11-09-2010, 01:10 PM
m1franck's Avatar
Also, install shorter 8mm x 37mm threaded studs, plus new lock and barrel nuts. Here's the studs you will need:
Pelican Parts - Product Information: 999-062-006-02-M260
Old 11-09-2010, 01:33 PM
1980 911 SC
Adidas,
you had another post earlier about "backdating" from an 83 system to a 74 system. I don't want to assume to much and don't want to insult anyone , but I need to ask....You do know that when you backdate a heating system in a 911 most people just switch out all the goodies up in the engine compartment and still use the existing exchangers? It would save you a lot of work.
Again I may be reading into this the wrong way. You may have another reason for doing this.
Life's a Beach
Old 11-09-2010, 01:45 PM
Senior Advisor
And I know the SSI's are expensive but there is a difference. and, sadly, one of the only ways to go if you want heat.
08 Cayenne Turbo
Old 11-09-2010, 02:08 PM
Thanks for the input everyone. Sailchief I certainly see now this option which will save alot of work and money. I appreciate it.
Old 11-09-2010, 02:59 PM
