Inexpensive very easy kill switch
I recently had surgery on my elbow and couldn't drive the Porsche for a while. I knew the battery was going to be dead when I finally got around to taking it out for a spin because I have a slow drain on the battery that I have been meaning to chase down for longer than I care to admit.
Being kind of a gadget freak I decided it would be easier to instal a kill switch than spend the time tracking down the leak. I liked the idea of the extra security a kill switch would bring, and I could just use it to disconnect the battery when I was going to not be able to drive the car for a few weeks at a time. Here's the car. ![]() I have already moved a small battery to the smugglers box ![]() I wanted something that could be reversible if I wanted to take it back out, didn't require any mods I couldn't reverse. My plan was to remove the ash tray and install a kill switch there. First I removed the ash tray and mount then I bought, from my local Pep Boys, 2 cables, a kill switch, some hardware from home depot and a grommet from the Mustang I am restoring. ![]() ![]() I'm a big weight guy. My car weighs 2387lbs with a full tank of gas. I figured between losing the ash tray and mount I only gained a few ounces adding the switch and one extra cable. Next time I'll weigh it. I only had to drill one hole to mount the switch in the ashtray area and it does not interfere if I want to remove it and put the ash tray back. I ran the two cables thru an existing hole into the passenger compartment by the smugglers box right where I want to mount the switch ![]() ![]() ![]() ![]() ![]() ![]() Total cost under $30. Total time less than an hour. Steve
1982 SC Last edited by Cdnone1; 01-29-2010 at 12:44 PM.. Reason: spelling |
I have the same switch and am considering my options.
Did you run the NEG (ground) wires to the switch, If so all someone would have to do is cross the 2 terminals at the switch and it will start. I was considering welding a box for the switch or mounting it higher with a plate to make it harder to access.
1972 911E w/3.0 RS Replica 1988 M5 300hp 2016 Audi Q5 TDI |
I did use the ground, but you would have to cross the terminals plus have gotten around the ignition switch and steering lock.
It's not really for safety, that is just an added bonus. I really did it because it eliminates the battery dying problem and looks cool. My kid saw it this afternoon and thought it looks great. Steve
1982 SC |
Hi -
Looks nice and clean. Am I correct in assuming that with the way you wired the switch, it would not be good to turn it "off" if the engine was running? Only to be used after shutting the car off w/the ignition/key? Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Thanks and yes.
I shut the car off with it to see what would happen and all it did was kill the engine and all electronics. You can't hit it with your hand when shifting and you would be hard pressed to accidentally turn it off as it is a push turn switch Steve
1982 SC |
Model Citizen
Nice seats/steering wheel/deadpedal!
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
doesn't it get annoying to have to setup your radio (presets, fader, eq, etc) and clock every time you hit the switch?
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Thanks on the seat etc.
Yes I have to reset the radio but I really only use it for traffic reports or the CD. It doesn't have any fader or other stuff and my car is so loud that you can't hear much anyways I hardly ever look at the clock and it's easy to reset while I'm getting ready to go Steve
1982 SC Last edited by Cdnone1; 01-29-2010 at 05:25 PM.. Reason: spelling |
to stop the annoying resetting of the radio , just run another ground from the radio to the ground wire that runs from the battery to the switch .... that way the radio wont lose its stuff when the switch is thrown , the only time the radio would "die" is if the battery itself was disconnected ........
To keep the presets active with this cutoff switch, connect a fused (e.g. 8A) wire between the large ground cables. Thus, even though the switch is OPEN, current can flow to ground from the radio. If there's an attempt to crank the engine, the 8A fuse will blow due to the high cranking current through the system. However, this circuit can allow the battery to discharge during storage as this wire still provides a ground path. To offset any long term discharge, connect a battery maintainer to the system to keep the battery fully charged despite the active radio preset circuit, alarm, etc. Sherwood |
the "always hot is to the battery + and his switch cuts the ground, effectively cutting the loop as you stated but if you go from the radio ground to the back side of the switch (the one from the battery to the switch) the battery would as I said be connected to the battery wouldn't it ???????which when the switch was thrown the radio would still be connected to a positive and a negative , unless i am missing something ........ Please by all means correct me if i am wrong but my cars I did this way and I dont reset my radio (and have done others the same way) Last edited by 80-911SC; 01-29-2010 at 10:27 PM.. |
the radio has a "always" hot , basically straight to the bat +
the ground goes to the bat - his switch has two terminal one connected strat to the bat - "always" ground the second when switched disconnects the battery ground from the chassis assuming i am correct I'll continue if you connect the radio ground to the " always"grounded side of the switch you have a continuous ground and a "always" hot positive basically your radio is hard wireded to the battery . Correct ? so the presets will stay active .... I did mine this way and its fine, I have done others and they work also . Please feel free to explain the error of my ways if i missed it I can draw it out in crayon and scan in a schematic of the set up if any one wants Thanks for the back up Nine oh nine Last edited by 80-911SC; 01-29-2010 at 10:39 PM.. |
Sherwood ,
I haven't used your method but I am not going to call yo a dumba@@@@ for suggesting it but re read mine and you will see it will work, or read the last post that I spelled it out a little more in detail for you because you are obviously smarter than I am . If you cant get it with the second description I can get the crayons out or fire up auto cad and post it here if you need. if you are worried about my way leaving the switch with an open ground path that is true it does but so does yours , mine just seems liked a dumbed down version of yours but it does work |
Sherwood |
That's the reason why , many higher end 'kill ' switches have a relay that is also connected to the 'exciter' wire to the alternator ... which 'grounds' it Last edited by 0396; 01-30-2010 at 06:43 AM.. |
I think if the battery dies the alternator will continue to try and run the car, but if you interrupt the the electrical loop by disconnecting the ground nothing will work.
1982 SC |
dis connect battery and motor should stay running, if not see alternator trouble shooting guide But if you are having trouble with a dying battery which would explain the need want or urging to install the dis connect you may have just answered the ? of what is causing it . answer ? alternator . |
When I turned the disconnect switch off everything died.
I think there is a difference between a dead battery and an open loop electrical system. But I'm no expert you could be right Steve
1982 SC |
