robhamster's Avatar
Why does one valve adjustment go out after about 1000 miles?
84 3.2 totally stock with 115K miles on it. I adjusted valves successfully about 200 miles ago. The intake valve for #5 was the loosest. I got it right and all was good in the universe. 1000 miles later I heard the tick-tick and narrowed it down to #5 intake. I readjusted it and checked all again and once again all was fine with the universe. It is now about 1000 miles later and I am hearing the tick-tick and it is coming from the #5 intake.
What should I be looking for as a potential problem here. (spare me the look-in-the-mirror comments)
1984 3.2 Cab (now toy)
1975 911S (old toy)
Mercedes E350 W4 (snow car)
2007 911 Turbo (water and air pumper)
2012 Panamera 4S (for the wife, I swear)
Old 02-01-2010, 04:25 PM
Less brakes, more gas!
euro911sc's Avatar
Look in the shiny puddle of oil on the floor Just kidding
You may need a new elephant foot and lock nut. Perhaps it has just worn out after being loose a few times. This is a semi-educated guess.
The worst may be a warn rocker thread which would require a new rocker. That leads to wear issues as your cam and rocker wear together and now 1 will not match the other
The last thing is... and don't shoot me, are you sure you tightened it right? they move sometimes when tightening... and, if you REALLY cranked it you may have stretched it out.
Just some ideas
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 02-01-2010, 04:54 PM
abit off center
cgarr's Avatar
Sometimes the foot or valve stem can get a slight groove worn in them which make them almost impossible to adjust with a feeler gauge because of the ridge, it feels good with the gauge but you are measuring it on the high spots but it seats on the low spots. After you set it try rattling/feel it and see if it feels like the others.
______________________
Craig
G2Performance
Old 02-01-2010, 05:04 PM
PRO Motorsports
Tyson Schmidt's Avatar
Just want to add: make sure the oil spraybar isn't plugged for that rocker.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 02-01-2010, 05:23 PM
robhamster's Avatar
Tyson,
How do I check for that?
1975 911S (old toy)
Old 02-01-2010, 06:10 PM
timeless beauty
rcaradimos's Avatar
Bob
87 targa
Old 02-01-2010, 06:25 PM
I had the same problem. Always one "tappy" valve. Mine was number three. Just replaced the shaft and rocker. Not a bad job at all. But then again, I had dropped the engine. In any case, if this turns out to be your problem, it is not an expensive fix. Just a PITA!
Good luck.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 02-02-2010, 05:04 AM
What oil are you running?
JR
Old 02-02-2010, 05:32 AM
robhamster's Avatar
Coffeepooch,
I am running Pennzoil 10/40. I dont think this is an oil problem.
CCM911 - Thanks, I suspect I might have a worn bushing on that rocker arm. I looked at what Wayne is selling and it looks like an easy fix, even with the engine in the car.
I appreciate the help, folks. The ticking sound is driving me nuts.
1975 911S (old toy)
Old 02-02-2010, 09:57 AM
It may not be an oil problem but something is wearing more than it should. Since the reformulated oils were said to be less effective in lubricating the type of rockers that are in a 911 motor, if figured that I would add it to the list. It's probably one of the things mentioned earlier but you never know.
JR
Old 02-02-2010, 10:33 AM
robhamster's Avatar
Thanks. Someone earlier had suggested that the oil spraybar might not be working there. I am not sure where to look for that or even how to without trying to start the car with the valve cover off.
1975 911S (old toy)
Old 02-02-2010, 10:39 AM
The problem occurs more frequently on the turbocharged cars, so I'd suggest looking on the 930 forum for pictures. There are some there. Here's a thread that talks about the problem:
bad rocker?
And a photo, in this thread:
spray bar orientation
There are others, as well.
JR
Old 02-02-2010, 11:07 AM
You really need to look into the oil you're using. The formulataion for almost all common motor oil's has changed in the past few years, eliminating some very important anti-wear additives for our old style motors. In essence, the main problem with these new oils on our old cam/rockers is very rapid wear, which would cause your adjustment to constantly go out as the rocker or cam lobe wears.
Lots of info out there on this, but something like Brad Penn (there's several others) oil is really critical anymore.
Bill
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 02-02-2010, 11:20 AM
robhamster's Avatar
RetroSC & javadog,
Thanks for the advice and the links. I am now armed with enough info to be just a little less dangerous as usual.
1975 911S (old toy)
Old 02-02-2010, 02:25 PM
loose guides at that mileage, if you have not had a top end rebuild yet.
206 637 4071
Old 02-02-2010, 06:07 PM
