Throttle switch replacement question.
Hello. I was wondering if this is a direct replacement or is there an adjustment required afterwards? Also, on a scale of 1-10, 10 being the hardest, how difficult is this job?
Thanks, Chris |
I found it tough to get to the screws.
http://forums.pelicanparts.com/uploa...1265564037.jpg http://forums.pelicanparts.com/uploa...1265564061.jpg |
Thanks for the info. I have a flat spot at around 2-3000 rpms and I'm hoping this will help.
Chris |
The full throttle switch only affects the engine at wide open throttle, changing the DME mapping. You checked for a vacuem leak, and the AFM from what I've seen. How about the oxygen sensor?
http://forums.pelicanparts.com/porsche-911-technical-forum/424978-ok-you-3-2-xperts.html http://forums.pelicanparts.com/uploa...1265582754.jpg |
That's a great chart. Thank you. The symptoms I have are a flat/dead spot from 2-3000 rpms then, as along as I stay on the accelerator the problem goes away and the car comes to life. I have had the reference sensors, fuel pump and fuel filter replaced. I have checked for vacuum leaks as well as cleaned the AFM. I am at a loss to the cause of the problem which has led me to this. If it doesn't work I will bring it to a shop and let them have a crack at it. If you have any suggestions I am more than willing to check them out.
Thanks, Chris |
The thing that stands out in my mind is that it seems specific to an rpm range-it doesn't mater what gear I'm in. Are vacuum leaks that specific? I would think they would be more random. Also, I have not replaced my O2 sensor. I've heard as well that rebuilding the AFM might help by adjusting the wiper arm but have not done that either.
Thanks, Chris |
This link is for the o2 sensor, disconnecting the o2 seems to give a quick result |
Thanks for the link. I will try that 1st. Where is the O2 sensor plug in the engine bay? Is it on the same bracket as the cylinder head temp sensor?
Thanks, Chris |
Look by your fuel filter. I have a 73.5 with a 3.2 conversion and I am not using one.
| All times are GMT -8. The time now is 06:08 PM. |
