brake pistons stuck
I am completely rebuilding the brakes on my '70T. Hard lines, flexible lines, new MC and rebuilding the callipers
The pistons are stuck and I can't pop them out. Callipers off the car and there are no lines that I can use to put hydraulic pressure on the pistons
I tried WD40 overnight as well as grip pliers and compressed air
Any other recommendations?
Thank you
Rafik
Old 10-05-2016, 02:41 AM
tobluforu's Avatar
Grease gun trick, but air should have worked. wd-40 is a lubricant, if rusted you need something like kroil (to help).
Old 10-05-2016, 03:24 AM
You could reattach them to the car, bleed the system, block all but one caliper piston from moving and push the brake pedal to pop each one out. Time consuming, but without a homemade bracket with a bug master cylinder, brake hose and pump handle held in a vise, what can you do?
206 637 4071
Old 10-05-2016, 04:58 AM
Try this one, he sells a kit. Air did it for me last week, but yours may be different.
https://www.youtube.com/watch?v=qc4zlGaJgoA
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-05-2016, 07:07 AM
Get bleed screws in every hole. Fill the caliper with water. Squeeze it in a vice, one piston at a time.
Only works if the pistons are somewhat out of their bores.
Old 10-05-2016, 08:38 AM
Had to make this jig. Worked on a couple so far
Old 10-06-2016, 02:29 AM
That should work if you bolt it down to your bench. clean up one piston and bore and reinstall, then clamp it and pop the other one out.
206 637 4071
Old 10-06-2016, 09:58 AM
My next (and hopefully last) question, is it better to reuse the original pistons with new seals or snap the pin in the caliper and use the new pistons I got from Bigg Red?
Old pistons look ok, see picture
Old 10-06-2016, 01:08 PM
