901 gear box
Just a quickie, posted in wrong fourm yesterday... (numpty ) anyways have found a 901 gearbox for sale and need some info, seller says its been rebuilt and has paperwork Nos on underside are901/7 and 7191947 in addition to these there is a small casting mark in a circle 25/68 any help much app and so on dont know what these thing are worth he wants 1k ...? worth it ? ... cheers stoney
Old 02-07-2010, 07:07 AM
Grady Clay's Avatar
Stoney,
I suspect the type number is 901/07 not 901/7.
The transmission number 7191947 is consistent with type 901/07.
This is a 1969 sand-cast aluminum 5-speed transmission.
As original it is geared:
1st = ‘A’ = 11:34.
2nd = ‘F’ = 18:34. (reinforced – 14 mm threads)
3rd = ‘M’ = 22:29.
4th = ‘S’ = 25:25.
5th = ‘Z’ = 29:23.
R&P = 7:31.
This could have been equipped with a ZF LSD.
You should check to see if the opposite flange turns same or opposite when the other is turned. Same direction = LSD.
If the normal (open) differential, it is the ‘simplified’ version and MUST be updated. Search Pelican on “simplified differential”.
The casting date 25/68 (25th week, 1968) is consistent with an early ’69 transmission.
EDIT
The clutch arm ball pivot is positioned for the 215 mm push-type clutch of ’64-‘69 (and not for the 225 mm pull-type clutch of ’70-‘71).
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 02-07-2010, 07:35 AM
re gearbox
Thanks ...my god that was fast !!! if all my Qs in the fourms over here were answered that fast things might not take that long a big thank you, the ammount the seller is asking £1k about right ? or way off
Old 02-07-2010, 07:49 AM
GaryR's Avatar
Send a message via ICQ to GaryR
That's a great price for a rebuilt anything (about US $1564.95).
Gary R.
Old 02-07-2010, 07:58 AM
Grady Clay's Avatar
Please post all the details of the rebuild.
For that much money, it should be exactly correct.
You don't want to pay £1k and find you need to spend that much again - or more.
A 3rd-party inspection (PPI) might be in order to confirm the work and condition.
The cost is a few paper gaskets and paper shim gaskets.
What is your use? Whet year, model 911?
Best,
Grady
Old 02-07-2010, 08:42 AM
gearhead
If that's got a factory LSD in it, 1000 pounds is a giveaway even if it hasn't been rebuilt.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-07-2010, 05:01 PM
