dsmyth's Avatar
Can I glass bead this exhaust?
I'm just looking at cleaning it up a bit. Will glass beading help or increase rusting possibilities? thanks Doug
Doug
97 C2S 993(last one)
95 993 cab- 85 911 M491
87 944 Turbo- 70 914-6
63 911
Old 02-10-2010, 04:42 PM
use navel jelly first to remove rust. that should get most or all of it. i'd probably soda blast anything rough after that. Soda blasting will actually prevent rust from returning for a while. Maybe use a high temp flat paint to protect it in the future. I think mine is painted either grey or black.
Jeff Lyons
Old 02-10-2010, 05:13 PM
Hey Doug, it looks to be stainless, may be 321 or 400 series (if magnetic 400) the outlet looks a bit corroded but also the hottest spot on it (inlet & outlet within a few inches) my though ti yes you can,
BUT
What are your goals just a clean up for now,?? Also you should be able to shead more light on it, with more info, I think I can see a part number or a manufacturer, that would be a big plus for determining materials.
Regards
Old 02-10-2010, 05:16 PM
dsmyth's Avatar
Thanks for the info gents. The number on it is 930 111 043 00 BISCHOFF 0/85 It is magnetic and I would like to restore the stainless look or go to a flat black paint if necessary? Doug
Doug
63 911
Old 02-10-2010, 05:31 PM
Senior Advisor
James Brown's Avatar
One of the problems of blasting it is they tend to warp so go lightly, or paint. There hard to see after installed so......why bother?
08 Cayenne Turbo
Old 02-10-2010, 06:16 PM
AutoBahned
RWebb's Avatar
rub that stuff that Eastwood makes into it...
Old 02-10-2010, 08:10 PM
3.4 Bigger is better
88-diamondblue's Avatar
I sandblasted my exhaust and VHT clear coated it. The clear has turned a slight bronze color and has not burned off even at the exhaust flanges..
This is how it started
Sandblasted and baked. The euro pre-muffler is not sandblasted or painted
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 02-10-2010, 09:08 PM
Carrera Cab Connoisseur
nyne11's Avatar
Vapor blasting is also an alternative with less chance of distortion and also gives a finer finish. Used extensively in the aircraft industry.
Dave
1986 Carrera Wide Body Cabriolet
1993 Nissan 300ZX Twin Turbo (620rwhp)
2003 BMW 330Ci MSport Individual
1973 Mercedes 350 Custom Convertible
Old 02-11-2010, 03:24 AM
spence88mph's Avatar
Really nice work Michael! Looks great.
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 02-11-2010, 03:36 AM
dsmyth's Avatar
That does look great Micheal. I thing I will go that route. thanks Doug
Doug
63 911
Old 02-11-2010, 04:37 AM
