73T - P O R S C H E Scripts
Following the post by MikeB over on DDK, I decided to get out there today and do the engine lid PORSCHE script.
However, upon opening the script, I found it to be 36mm too wide ! So I used Mike's method of marking the letters on a piece of tape, but then moved each letter 6mm to the left, thus taking out 6X6mm = 36mm. As you can see, it was a case of measure twice and fix once, but well pleased with the result. Here are the individual letters cut and re-applied in their new position before peeling the backing from each and sticking down. http://i124.photobucket.com/albums/p...s/DSCF5207.jpg http://i124.photobucket.com/albums/p...s/DSCF5209.jpg http://i124.photobucket.com/albums/p...s/DSCF5210.jpg http://i124.photobucket.com/albums/p...s/DSCF5212.jpg Next it is the side script. Ian |
The side script was applied to a wet door panel, as there was no way I was going to do it direct.
Getting the measurement and position took ages, but eventually I applied wet and then pressed on and use da hair dryer to thoroughly dry before removing the top covering. This was a pretty tough job, and there are a couple of small air bubbles but it is OK as it stands. I still have the RH one to do, and the bumper stripes (but I will sleep on that decision). I just hope they stay stuck down ! http://i124.photobucket.com/albums/p...s/DSCF5214.jpg http://i124.photobucket.com/albums/p...s/DSCF5215.jpg http://i124.photobucket.com/albums/p...s/DSCF5216.jpg http://i124.photobucket.com/albums/p...s/DSCF5217.jpg http://i124.photobucket.com/albums/p...s/DSCF5218.jpg http://i124.photobucket.com/albums/p...s/DSCF5219.jpg http://i124.photobucket.com/albums/p...s/DSCF5220.jpg Ian |
side scripts
Ian, Nice job all around. That looks great. Here is a look at my '73 T with the bumper stripes also applied. I had to go with red to match the interior. Cheers. Mike.http://forums.pelicanparts.com/uploa...1266173469.jpg
http://forums.pelicanparts.com/uploa...1266173485.jpg http://forums.pelicanparts.com/uploa...1266173500.jpg |
Finished off the right hand side today and then went for a run out in the Cotswolds.
http://i124.photobucket.com/albums/p...s/IMG_0018.jpg http://i124.photobucket.com/albums/p...s/IMG_0030.jpg http://i124.photobucket.com/albums/p...s/IMG_0045.jpg http://i124.photobucket.com/albums/p...s/IMG_0048.jpg Stopped at doing the bumper stripes as I want to see how I feel about it in time. Ian |
Gorgeous!! It looks brilliant. Nice job.
| All times are GMT -8. The time now is 11:20 PM. |
