jamesjedi's Avatar
How To Sell a 3.6 Engine?
I am going to sell a 3.6 M64-01 engine. The engine has not run in long time. I want to sell it correctly, with proper representation. My plan is to do a dyno/leak down test, but what else can I do? I have no interest in misleading any purchaser, as this was a race car engine.
The following is the engines history;
- The engine has sat for a long time. It is my hope to have the dyno and leak down numbers completed in a few weeks.
- Engine was in a race car. It was raced by Gary Griffiths in the One Lap of America. in 1997 and 1998, he changed to a 3.3 turbo in the following years. I purchased it as a long block from him.
- He bought the engine originally with +/- 25,000 miles on it. He rebuilt it and ran it for +/- 5000 kms with a TMW throttle body kit and Electromotive Tec 1 EMS.
- The engine was then destined for turbo charging and 500HP, it was then pulled apart again and strengthened the lower end with Raceware fasteners to take the extra load, cleaned up the webs to improve flow within the case and assembled with turbo pistons and cams. Gary removed the turbo P's and C's and reinstalled the original P's and C's. Engine has not been run since.
The following is the present build;
- 5000 km’s on all new bearings, rings, guides, seals, 3-angle valve seats and slightly polished intakes and exhaust ports.
- Raceware rod bolts and head studs
- Patrick 3.6 DME to 915 lightweight flywheel
- 964 Group “B” Camshafts
- stock 964 M64-01 piston and cylinders, with new rings
- Direct ignition Electromotive trigger wheel installed
- 993 exhaust headers (no cats or mufflers)
- 964 throttle body
- 993 Plastic intake
- 993 injectors
- 964 ECU with Steve Wong Chip
Thanks for any help!
Old 06-21-2016, 05:58 AM
Mick_D's Avatar
If you want to dyno it you're going to have to get it running at the very least.
Old 06-21-2016, 09:59 AM
gtc gtc is offline
abides.
gtc's Avatar
If I were a buyer, I would either want it apart to verify that the parts listed are present and serviceable, or running with test reports to verify the condition and output.
Graham
1984 Carrera Targa
Old 06-21-2016, 12:39 PM
jamesjedi's Avatar
That is the main reason I have asked this question. I want to know if I really need to have the cams checked and the connecting rod bolts. Perhaps it is worth doing, as these engines have become valuable.
Old 06-21-2016, 02:52 PM
Cars Ruined My Life
impactbumper's Avatar
Or you would put a cheap price as is and not deal with anything. Hint hint
Old 06-21-2016, 04:43 PM
jamesjedi's Avatar
I am also interested in full disclosure and attempting to provide as much information on the engine as possible to a buyer.
Old 06-21-2016, 05:42 PM
Eva
911SauCy's Avatar
If it were running, you should PM me...
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 06-21-2016, 05:53 PM
jamesjedi's Avatar
I will be installing it over the next few weeks.
Old 06-21-2016, 05:56 PM
I'm interested in learning more. "installing" it? Or selling it?
Old 06-22-2016, 02:23 AM
jamesjedi's Avatar
Needs to be installed to do a dyno. Installed in my car.
Old 06-22-2016, 04:05 AM
jamesjedi's Avatar
To clarify the above post; yes I will be selling it. I could get a dyno done on a stand, but I do not have one local. They are not very common.
Old 06-23-2016, 10:03 AM
jamesjedi's Avatar
Thanks to all who contributed.
I talked to a local P car race shop. He said that the engine hardware would be easy to identify by the markings on the bolts. As for the cams - I have the overlap measurements. Valve covers could be removed to identify the case bolts. Fairly easy to do. Much more than that may involve tearing the engine down, however I am open to suggestions.
A leak down test is best done when engine is cold, as this provides an honest test vs. having the engine warm.
I will now focus on getting it started and running.
Old 06-23-2016, 12:34 PM
