Cool 17" wheels to fit 1980SC
Hi Guys ,
I want to run fronts: 7 x17 ,Rears: 9 x 17 wheels and run 993 TT Calipers my 1980 911SC race car .In regards to Wheels ,what ET should be using bearing mind I will have to use Turbo Hubs on the fronts .
Could I run Cup1 or Cup2 wheels, cheers Dave
Old 08-05-2010, 02:21 PM
Jeff Alton's Avatar
A couple of question first...
Why do you need turbo hubs on the front?
How about 8.0 on the front as it is a race car and it is an easy fit?
If you use the standard hub up front and an 8.0 wheel you need 25-31mm offset. On the rear your 9.0 wheel will require 15-19mm offset.
We have a set of new Fikse FM10 in stock..
Cheers
www.turn3autosport.com
Old 08-05-2010, 05:48 PM
Bill Verburg's Avatar
Cheers
exactly!
I have 993RS brakes on my C3, the flat hats used on std 911 hubs is the easiest part of the install.
w/ a bbk you want to get as much tire, especially in front, as you can get.
Bill Verburg
Old 08-06-2010, 05:01 PM
Hi Jeff ,I thought I needed T/hubs on front but if I can use my standard hubs ,thats great .So to confirm I can run 8's on front and there is no problem clearing wheel arches . cheers dave
Old 08-07-2010, 07:05 PM
Jeff Alton's Avatar
No problem with a properly specced set of 8.0 wheels up front. Use standard hubs and any of the readily available flat hat/rotor combos available.
We spec our 8.0 inch fronts at et30mm.
Let me know if I can help with wheels or brake purchases!
Cheers
Old 08-07-2010, 11:35 PM
