Rear grill fit question and rant....
Has anyone else run into this? I bought a used lid and grill here and had it painted to match my 85. The black grill seems to attach properly on one side but does not have the same shape as the lid on the top side. Its not a warping issue as its not the same shape as the metal tab and leaves a gaping space on the top.
I can cut it I think to fit but just wondering if anyone else has run into this and how did they remedied the problem. I should have known when it was not shipped attached in the first place. Why do people do (sell) this sort of stuff?????. thanks Doug![]() ![]()
Doug 97 C2S 993(last one) 95 993 cab- 85 911 M491 87 944 Turbo- 70 914-6 63 911 |
Senior Advisor
Are the p/n's the same? is that grill for a 85? Looks like a big gap at the top. Don't think cutting it will help.
08 Cayenne Turbo Last edited by James Brown; 02-16-2010 at 08:51 PM.. |
a.k.a. G-man
I had the same problem.
Don't know why it is that way though. (probably mismatch of years) Cutting it should help. (Haven't done it myself yet as I am rebuilding, not driving...) Following this thread to see if anybody knows an answer
Сидеть, ложь, Переворачиваться Last edited by Geronimo '74; 02-17-2010 at 02:27 AM.. |
I know youŽll need to repaint it but is there any way to stretch it by clamping the sides and with heat stretching it along the length
a.k.a. G-man
Heating and stretching is an option but requires repainting (like twistoffat said)
Dremel it, two minutes, perfect fit, no repainting.
Сидеть, ложь, Переворачиваться Last edited by Geronimo '74; 02-17-2010 at 09:27 AM.. |
Would you suggest to Dremel the metal or the wood? thanks Doug
a.k.a. G-man
I don't know what you mean with wood. The grill is plastic.
Do not dremel you deck lid! Dremel the plastic part that is touching the metal lid and preventing it from coming further down to a nice fit. I marked the two locations, you can't miss. Good luck, don't dremel too much at once, once it's gone, it's gone. Remove material step by step, you can always remove some more if needed.
Сидеть, ложь, Переворачиваться Last edited by Geronimo '74; 02-17-2010 at 09:29 AM.. |
Thanks Geronimo ,and others , I will give that a go tonight. Not sure where the wood came from? not much of that on the car !!!! Doug
Alii&Maui
![]() (Pic1)The space between the grill and lid is the rubber washer/spacer ![]() (Pic2) No interference like yours ![]() (Pic3) The bottom is flush but there is a rubber washer/spacer installed IMO if you want a clean install get another good used one in the for sale/ wanted forum.
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
