Blinker housing rebuild
I have found several threads about the blinks housing rebuild. The problem that I have is that the reflective paint is spotty. I tried to use silver polish, not so good. I was going to paint the surfaces with chrome paint, but found this online:
Paint your bike / bicycle / gear reflective!
Has anyone tried this? Any reason why it might not work?
Essentially, they take clear coat, spray it on the old reflective surfaces, and then cover the surfaces with reflective glass beads. Thoughts on of this might provide a better reflective surface??
Karsten
1977 Turbo Carrera - Work in progress
1971 911E Targa - Almost gone
Old 02-19-2010, 04:59 PM
Slippery Slope Victim
NY65912's Avatar
I've used the reflective paint on a tailight housing with very nice results.
Eastwood Company: Search Results for reflective paint
MikeČ
1985 M491
Old 02-19-2010, 05:11 PM
Thanks for the link
Karsten
Old 02-19-2010, 05:24 PM
E Sully's Avatar
I just finished redoing my 73.5's. They were in bad shape. I wire brushed and sanded the exterior, then coated them in JB Weld. I finished them with Rustoleum Bright Coat Metallic Finish.
Old 02-20-2010, 11:47 AM
'82 SC TL
canamfan's Avatar
Can't say I've used that reflective/glass bead method, but it looks like it would be a good idea. In a pinch I've used the chrome/aluminum duct tape and very carefully cut out the pieces and dimensions required & stuck them in place (this worked cosidering the high temp. in these housings just because of their location). Eastwood looks like it would work too (unfortunately in Canada, it's all but non-existant) & I thought that clear coating usually dulls the finish abit/however slight. I've always wanted a very high reflective clean finish that would withstand the temp. & give a bright light to shine off of, without breaking the bank. It'll be interesting to see some fixes for this.
76'S 1st Porsche white/can/can early rebuild (boo)
'84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1)
'87 Carrera cpe white/blue short flirt
'89 Anniv. sil/linen very pretty miss her
'88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Old 02-20-2010, 12:01 PM
