Axle Rod Removal Question
Hi all,
It's time for me to R&R the CV joints and I have a question. I assume that I have remove the big Axle bolt that holds the Axle rod on without having to take the wheels off. Is this correct? The car is up on my 4-post lift so I don't have any problems with clearance but I'd prefer to not remove the wheels if I don't have to. Thanks in advance, Michael
-- '87 Diamond Blue Coupe -- '92 Miata -- '06 Scion XB (the wife's) -- '01 Audi S4 (Sold) -- '17 Tesla Model S60 |
It is not necessary to remove the big castle nut to R&R the CV joints. Just remove the screws in the joints. You only need to remove the nut to replace the wheel bearings. This is discussed in detail here.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
The 87 Carrera has a solid axle so the nut has to be removed to pulll the axle off.
Bruce |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Michael
Friend of Warren
No you have to remove the rear wheels to get at the axle nut. And you will either need a really long breaker bar or a serious impact wrench and the torque on the rear axle nut is 230 lbs!
Michael
3.4 Bigger is better
This should help some Carrera CV Boot Replacement Diamond blue, great color. I biased though
![]() You can remove the nut with the wheels on the car and it is torqued to 330-340ft lbs. It is recommended to loosen the nut with the wheels on the car and on the ground. I didn't do that but would do that if I need to take them off again.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport Last edited by 88-diamondblue; 02-19-2010 at 10:04 PM.. |
Take care, Michael
This may be heresy, but if you take a crappy (aka soft) #1 or 2 phillips screwdriver or something similar and jam it in between the brake rotor fins so it bottoms against the caliper, you'll have no problems loosening the axle nut (worked on mine, at any rate). On some of the domestics automobiles, this is actually the "proper" procedure for hub & bearing R&R.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Well, Removing the nut while the wheels were grounded worked out great! I had no problem getting it off. Now my problem is I didn't realize you needed to remove the bottom end of the shock so you get enough clearance to remove the axle and wouldn't you know it but the shock bolt won't move no matter what I do! I've tried a big a$$ breaker bar, impact wrench, and tapping the bolt with a mallet with it not budging! Now I have them soaking in PB blast so I can attack it tomorrow.
Thanks again for all the advice, Michael
