-   -   Camber Tool Instructions (http://forums.pelicanparts.com/porsche-911-technical-forum/527701-camber-tool-instructions.html)
Superman 02-22-2010 10:07 AM
I've got a camber tool, but no instructions. I know how to set camber, but don't know how to set caster. The tool has three bubble level thingies on it, and a dial that can move at least one of the bubble thingies. I know there is a procedure for measuring caster, and I need to set my caster to a particular value (5.5 to 5.6 degrees). Can someone walk me through the procedure?
Also, what is "stock" toe on these cars, front and rear. Zero front and zero rear?
Superman 02-22-2010 02:19 PM
Bump. Somebody knows how to operate a bubble camber/caster tool.
Superman 02-24-2010 09:57 AM
Bump. Bubble camber/caster tool. Anybody know how to use this to measure caster?
KTL 02-24-2010 10:08 AM
Send cgarr a pm. He and his brother Denny know how to use that pesky gauge
RE align specs, do a search for a topic you previously created- Toe Adjust Techniquest = the Ray Scruggs home alignment procedure. Don't you remember? :D
http://forums.pelicanparts.com/porsche-911-technical-forum/97217-toe-adjust-techniquest.html
BTW 15 min. "IN" is the typical toe spec for these cars.
http://forums.pelicanparts.com/porsche-911-technical-forum/297155-how-measure-toe-out.html
