Senior Member
Toe Adjust Techniquest
Guys (and ladies, of course), can someone direct me to a good technique for assessing how much toe-in or toe-out I've got. I'm going to check that tonight in my garage and I wonder if a couple of pieces of lumber (straight as I can determine) can be tied to the wheel/tire to see what kind of toe geometery I've got.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Senior Member
Oh, c'mon. Somebody's got to know how to do this in their garage.
I used this before. Worked great!
http://www.allpar.com/fix/alignment.html
72 911 Although it is done at the moment, it will never be finished. |
Superman, I have heard of people using a stick of metal conduit, placing it in front of the wheels, marking the outer most edge of the tire, then doing this to the rear. Then they measure the differences and do some math to figure out the toe.
There's also an articl on theTechnical how to page here at Pelican. http://www.pelicanparts.com/techarticles/home_toe_in/home_toe_in.htm |
Senior Member
Awesome. Just what I was looking for.
similar to the method in the link is to use a tack with a string and a small weight of some sort (like a plumbob (sp)) hang the tack off of the extreme rear of the tire (both sides at the same time) mark the spot on the ground, then push the car forward until the string is hanging off of the extreme front of the tire and then mark that spot on the ground. You then just measure the difference between the two marks and that is your toe.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
![]() Quote:
different strokes for different folks, LOL..............Ron ![]()
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Doh, I should have read the rest, that method is in there. hehehe
Ron, where can I get a copy of that book?
![]() Quote:
to my understanding.. I have the last copy in the whole world.. I could do a 7 pic scan to the chosen few on this "subject"as a reply.. what do ya think.. I try not to...........Ron
Ron,
DO IT, DO IT, DO IT! please?
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
I would apreciate that very much!
Hey, I want it too!!!
I like to spin the tires while on a jack and draw a line with pointed chaulk arond the whole tire right in the center of the tread. Lowere the car and roll it back and forth to set the suspension bouncing the car a little. With two people, measure the front and back distances between lines w/o any movement in between measurements. The difference is your toe. This method is compromised a little on a p-car as you cannot get the tape across from tire to tire at the extreme back and front of tire. So your toe is actually a kittle more than you read. Works great on some cars, not so good on others, but I think it is a good method to know about.
![]() Quote:
Thanks!
That booklet looks like a "must-have"
It would be great to get a copy. Thanks
Bob D |
Ron,
Can you send a copy my way as well........ ![]()
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
I believe he's going to post it here.
