Rear Shocks Done!....Are you kidding me!!!
I sure hope I never meet the German engineer that designed the rear shock top mounts and didn't allow for the shock rod to be indexed so it doesn't turn when you try and loosen the nut. And since there is acres of room up there it's real easy to grab the top of the pin with a set of vice grips to stop it from turning....NOT!!!
And this is the very first time I removed the rear clips on my air filter box. Usually I just undo the two on the front and slide the filters in and out. But to access the top of the right shock you need to remove the cover. I bet there are very few 911s running around with that rear bottom clip attached properly. Unless you have VERY small hands and wrists, there is no way you are going to reach it........... ![]() I wrote a whole article with pictures and the tools I used to perform this shock replacement. It will be on my web site momentarily RVB Precision - Welcome to the world of ultra precision Now I have to go stop the bleeding on all the cuts on my hands and wrists.....
RoyB Dartmouth, Ma 1987 Targa, Black on Black Photo Album http://public.fotki.com/Rbertalotto/ |
It's been a while since I did this, but I believe the top of the shock rod has a hex-head recess to hold the rod from turning. Also, I have found it is easier to reach the rear airbox clips by reaching up from the bottom of the airbox instead of from the top and down.
Edit - That might have been the Bilstien Sport replacements, not the original shocks, with the hex recess... Wow...I even had a picture...
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 02-18-2010 at 09:37 AM.. |
The shocks that came out and the replacement simply had a couple of flats for a small wrench. The hex head is a good idea, but it would have been tight even for that on my car. Your car looks like it has tons of room up there. No AC? I've got hoses and pipes running all over the place above the shocks.
The article I wrote and the method I used to secure the shock from spinning is now up on my web page. Porsche 911 Rear Shock Remove And Replace | RVB Precision - Welcome to the world of ultra precision RVB Precision - Welcome to the world of ultra precision
I think most guys use a small wrench to keep the shock top from spinning. I have a set of shock installation tools made by Lisle Tool Co. I think I bought them at Pep Boys. If I remember, I'll grab them and post pics later.
It's not a good idea to not attach all 4 clips. The airbox will distort, and the air filter will not be doing it's job of filtering the intake air. Here's a tip that I swear will work. Loosen the AC compressor mounting bolts, loosen the belt, and remove it from the AC compressor. Then remove the 3 cap bolts that hold the compressor onto it's mounting saddle. Lift the compressor out, and place it on top of the intake plenum. Now there will be a hole where the ac hoses used to be, and you can put your arm through there, and easily reach the lower clip. Re-installing the ac compressor only takes a few minures. Done. |
Example: Adjusting bucket and shim valves on most motorcycles is a real pain in the arse. Twice I brought motorcycles to different dealers and put a thin piece of thread across the gap of the motor's head to see if they really did pull the head. In both cases, the thread was not moved and I was assured the valves were checked and adjusted. They even charged me for shims. Batstards! Mechanics usually get paid for speed. No mater how you look at it. The faster they are, the more money they make. This leads to shortcuts. If you have a mechanic that you can 110% trust, you are a lucky person.....Hold him close to your vest and tip him big at Christmas! (BTW, removing an AC pump to snap one clip is a deal breaker.............If I find that engineer, he's had it!)..... :-) The box only needed a couple of tabs and two slots on the back side. We're not reinventing the wheel here!
RoyB Dartmouth, Ma 1987 Targa, Black on Black Photo Album http://public.fotki.com/Rbertalotto/ Last edited by RoyB; 02-18-2010 at 10:26 AM.. |
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Bob F. 1984 Carrera Factory Turbo-Look |
Formerly known as Syzygy
I had a similar issue with mine at a "reputable" shop in town. They screwed up once by overfilling my oil by two quarts. The service manager was kind enough to replace my filter for free, clean up any oil on the engine and offer my next oil change for free. I checked their work after I got home and lo and behold, both clips on the back of the air box were not on.
When I hooked them back up, I too found it easier to get to the lower clip from below. I just recommend waiting until the oil has cooled. Never mind the minor cuts and scrapes. Those burns can be damn painful.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Try replacing shocks on a carbed car. It's cake. That is how those German Engineers designed it. It was brilliant. As the car evolved from the original design, access got harder. First with the CIS in 73.5, then finally with the EFI it was hopeless. The solution is to drop the engine down about 6 inches to gain access to the shock tops. Once you know how to lower the engine, it is a 5 minute operation. This is far, far faster and easier than trying to grow the needed extra joint in your forearm to install with engine in place.
Chuck Moreland - elephantracing.com - vonnen.com |
"Zis is ridiculous! Make it easier to change ze shocks!"
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Are they supporting the car with the jack under the engine?!? And no jack stands with someone laying under the car... Tsk, tsk...
Senior Member
This is a good application for one of those ratcheting stubby wrenches.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
A stubby, flexible, 17mm ratchet wrench, that I had to purchase to change out the oil sender (another reason to want to find a Porsche engineer in a dark ally) was what I used on the top of the shocks..........Worked great!
A 3.2 engine with a "sectioned" air filter housing.... a la "Cup" cars.... is the ticket. Gets rid of that snorkel and the removable part of the air filter housing allows you to both "see" and actually "use" all 4 clips !!!
Found this link---> Cup filter lid
Wil Ferch 85 Carrera ( gone, but not forgotten ) Last edited by Wil Ferch; 02-21-2010 at 05:49 PM.. |
You should try replacing the rear shocks on a Ford Crown Vic! Usually rusted badly and fuel lines right in the way! I'll do 911 rear shocks anyday over these!
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
How would you know the rear shocks on a Crown Vic even needed replacement.....
It's one of those jobs that you only do when you absolutely have to! And considering that you ony get paid a little over an hour for both, I'm sure that they hardly ever need replacing!
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
