Welcome to Porsches. Jason |
My method of finding the leaks was in the dark garage, I shined a light and voila leaks appeared. I went ahead checked all around the body and chassis and discovered more and used weather sealant and plugged all the leaks.
OP, when you replaced the nozzles did you seal them? |
Could this also be called "my 911 does not leak oil"
From my experience these (faults) go with the driving experience |
I have noticed that the clock and speedo gauges never fog up because they both have holes in the glass (knobs) for resetting the speedo and setting the time. If only I have the guts to drill a tiny hole on the other gauges
I took all my gauges apart very carefully and used rainex anti-fog on the inside of the glass. When reassembling I went to a shoe store and asked for 4 small packs of desicants from the shoes they were selling and taped those to the inside bottom of the gauges before everything went together.
I've been fog free for 3+ years. - Steve |
Worked like a charm. Give it a try, you won't be disappointed |
I have my air box, brake master cylinder and other bits removed, and I am dealing with windshield squirter repair. I am noticing what others have reported, which is that the windshield squirter system can leak. Mine does. If so, it leaks into the perfect place to provide unwanted humidity to the gauges.
In my view, one could attempt to address the problem by trying to seal, or vent, the gauges. Alternatively, one might find the source of water/humidity and address that instead. |
Think about the physics. Moisture is condensing on the inside, so the outside surface is cooler than the inside. Otherwise the condensation would be on the outside of the gauges. I wonder how much heat the gauges produce in operation, with and without the interior lighting on.....
BTW, as you can see, I have been here a while. I've heard of, and experienced, the dreaded foggy instrument problem. What I also notice is that most cars have no problem with this whatsoever. It is not the gauges' fault. Water is getting in.
Keep thinking that you have a water leak and you would sit with this problem for years.
I never drive my car in the rain and my car is always parked in a garage. I took out all my gauges and used a sheet of thermal fibre to keep out the cold air. I keep my car cover in the trunk packed up against the windscreen. I also got a company to make me 3 bags of 250g silica gel that I placed behind the gauges. I even replaced the candles with CarMagic's led bulbs, None of this helped. To each their own. Some people can't use good advice |
Moisture laden warm air will eventually get into your gauges, then it is there for a long time since the air transfer in or out of the guages is slow. When the car cools down the warm air cannot hold the moisture and it condenses on the cold glass. Drilling a hole in the back of the guage makes sense, like opening the window in the shower.
Rahl |
While a cool idea.... and I admire your initiative.... It seems like a lot of work to wrap the offending gauges in a heating blanket..... I'm not sure I would go that far. I'm an engineer and I love a challenge but this seems over the top.
Temp guage fogging
Hi, I noticed my temperature gauge fogs when the car is idling and stationary.
Any ideas ? |
The AC must suck the moisture out of the car, and the gauges. |
They all fog up. Mine always have. I have read that if you get the inside of the glass cleaned up, they will fog less. I wouldn’t bother possibly ruining you gauges just to dry them. They will dry on their own |
| All times are GMT -8. The time now is 07:42 AM. |
