When to rebuil engine?
Thinking about having engine rebuilt and was wondering all those who have your engines rebuilt I have following questions:
1. What is your engine size?
2. mileage at rebuild?
3. What prompted you to do so?
In his book Bruce Anderson said 100K to 120K.
84 911.
Old 11-25-2001, 08:25 PM
How soon you need to rebuild depends on your driving and maintenance habits, and the type of engine you have. The 3.2 engine is very strong and unless you are unlucky with the valve problems you could get a lot more than 120K before a rebuild is necessary.
64 356C Cabriolet
85 Carrera Coupe...Walker-maintained...Wong-chipped
02 Yukon XL 2500
82 Vespa P200E
186,000 MPS.....not just a good idea....its the Law!
"Too much of everything is just enough"
Old 11-25-2001, 08:32 PM
Just had a top end rebuild on my 3.2 @107k miles.
Excessive oil usage was the main reason to go ahead with the rebuild. Worn valve guides were definitly an issue.
Old 11-25-2001, 10:35 PM
ronin993's Avatar
test
just a test
ronin_993@yahoo.com
Old 11-25-2001, 11:07 PM
Rollins's Avatar
Send a message via ICQ to Rollins Send a message via AIM to Rollins
How much does a rebuild cost on say an SC ?
Old 11-26-2001, 12:57 AM
Wink
IMHO, a full rebuild is a consideration if you have top end problems at 100k+ miles. Internal parts will show wear and if you will keep the 911 you might want to keep it bullet proof. True, it may keep running till 250k. Perfection in my 911 became an obsession, be carefull.
Old 11-26-2001, 04:53 AM
Not Quite Banned
Thomas Owen's Avatar
'88 3.2
Needed only valves/valve guides but I did the entire engine since I will keep this car.
Thomas Owen
1972 911T
1972 911S
Old 11-26-2001, 05:34 AM
Porsche Crest Q: When to rebuild engine? A: Don't!
The serious answer to "When to rebuild your 911 engine?" Is "When it breaks, not before!"
Panic stricken owners (usually new Porsche owners) rebuild their engines out of fear that "something will might go wrong." To try to avoid the cost of a mysterious and sudden engine failure, which is highly unlikely and will probably never happen, they end up spending a guaranteed $5-10k on a fully engine rebuild!
Ironically, this is very near the cost they would spend even if they did suffer from catastrophic engine failure. Even if you put a rod through the case, the additional cost of replacing or machining the damaged parts is simply not very significant compared to the overall cost of most rebuilds.
This raises the question of "when does a 911 engine break?" That answer is (except for the unfortunate later 2.7s in hot climates) "We don't really know, because most idiots rebuild their motors before they need to do so, thus depriving us of the data we need to answer this question." Very few 911 engines die from natural causes if they have had even the most basic of maintenance (valve adjustments and oil changes). The majority of catastrophic engine failures are from operator error - overrevving the engine on a missed downshift, or from simply running the damn thing out of oil. Yes, Bruce Anderson may have a picture of an engine that died from worn valve guides, the most common wear point. However, most worn guides will simply smoke more and more as the years go on, but won't catastrophically snap off unless the valves haven't been kept properly adjusted so they get the proper cooling, dissipating heat to the seats.
Bottom line, spend your money on routine preventive maintenance and driving your car as it was meant to be driven. If yours is the rare 911 engine that suddenly explodes (and the odds are very good that it won't be), the marginal cost of replacing the broken bits will not be material compared to the rest of your mechanic's bill, and will be more than offset by the interest you earned by leaving your money in the bank for all those years. Save the paranoia and needless expenses for other areas of life, like women and relationships, which seem to respond far less efficiently to logical routine maintenance . . .
Old 11-26-2001, 12:01 PM
Bill Douglas's Avatar
Well said David.
Old 11-26-2001, 12:41 PM
