Do I have to have a torque wrench for spark plugs?
Hello. all. I was just wondering if I have to use a torque wrench when installing new spark plugs. Also when checking for proper gap, I have a coin shaped tool. Is this okay to use?
Thanks,
Chris
Chris
95 993 C2
84 911 gone to to a new home
Old 02-28-2010, 06:24 PM
aadrew10's Avatar
The purpose of using a torque wrench is to not under tighten or over tighten the plugs. If you have a good feel for doing this, then you don't need a torque wrench. If you do not have a good feel for this, then you may strip out the threads or not tighten the plug enough. You are the only person who can assess your feel for tightening spark plugs.
I tighten my plugs by feel, but if I were you I'd use a torque wrench to be safe.
Good luck!
- Andrew
81SC
Old 02-28-2010, 06:32 PM
HarryD's Avatar
You mean something like this? If so, it will be fine.
As far as tightening the plugs, much discussion on technique.
I do not use a torque wrench. I hand tighten them into position until I feel the compression gasket start to compress, and then give it another 1/4 turn.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-28-2010, 06:35 PM
Thanks for the replies everyone. I have changed plugs before on the Karmann Ghia I used to own and did it by feel. I basically hand tightened them and them gave them a little turn after that. I'll give it a shot.
Thanks,
Chris
Chris
95 993 C2
Old 02-28-2010, 06:42 PM
Senior Advisor
James Brown's Avatar
I use a torque wrence on aircraft but they don't have crush washers. you can feel the washer contact the head and feel it start to crush, yeah about a 1/4 turn. But don't over tighten, the torque will increase sharply. If it does, take it out and start with a new washer. Be carfull.
08 Cayenne Turbo
Old 02-28-2010, 06:44 PM
78 in a '71
mossguy's Avatar
I started using a torque wrench some years ago, and I haven't had a plug break off since.
Best,
Tom
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 02-28-2010, 06:48 PM
80-911SC's Avatar
no torque wrench, but a real gap gauge would work better ..........
Old 02-28-2010, 07:30 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
no torque wrench, I have same gap tool. so far so good.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 02-28-2010, 07:37 PM
Almost Banned Once
sc_rufctr's Avatar
I've been working on my own cars for more than 25 years.
I always use a torque wrench...
This is what you need for a 911. But to start with just get a 5 to 75 foot pound wrench. (mid size with black head)
The big one is for gearbox and suspension work. Also great for torqueing lug nuts.
The smaller chrome wrench is a "Torqometer"... I last used it to check differential bearing pre load.
Can also be used for Phillips heads screws into plastic and plastic oil filter holders for a VW and modern water cooled 911 engines.
Also good for any task requiring light but accurate torque. (Home made tomato paste lids)
Mine are "Snapon" because I prefer American made tools.
But you don't to buy the same. Any good quality wrench is fine.
Always return it to zero and store it properly. Don't use it as a breaker bar.
And you should get it checked for accuracy regularly.
Once a year from a pro mechanic.... Every 3 years for an amateur home mechanic.
I have seen home made weight bars used to check torque wrenches.
- Peter
Old 02-28-2010, 07:51 PM
