Engine Drop Question
I am preparing for my first engine drop. Wayne's book indicates that I have to disconnect the "hard oil line." I assume that this is the hose that passes under the engine and connects to the left side of the block. Do I have to remove it entirely of just disconnect it from its attachment at the oil filter manifold under the right fender? I really don't want to take off the heat exchangers to get to it unless I have to. But that hose is really expensive. (For some reason, I can't download an image of it right now.)
Steve B.
1972 911t
1999 328is
Old 02-26-2010, 08:32 PM
efhughes3's Avatar
That is the line being referred to. But, I've always undone it at the CASE. It's been a while since I've had HE's on, but it seems that I could get to it when I did. I've never undone it at the RH side.
Chevies, Fords, Mopars, etc have blocks.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 02-26-2010, 09:13 PM
3.4 Bigger is better
88-diamondblue's Avatar
Just remove it under the oil filter console. I think this is what your talking about. Takes some big wrenches to remove.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 02-26-2010, 09:31 PM
Thanks guys. That's one vote to disconnect at the block and vote to disconnect at the other end (under the fender).
Any other opinions out there? The car is a '72 if that is important.
Steve B.
1972 911t
1999 328is
Old 02-27-2010, 09:53 AM
aadrew10's Avatar
Either way works. You could even do both if you wanted.
- Andrew
81SC
Old 02-27-2010, 10:05 AM
It needs to be disconnected as in the picture above. I took the hard line of after having the engine out and heat exchangers off. Maybe different on early cars but I could not have gotten the hard line off with the HE on
Michael
2020 Honda Passport
Old 02-27-2010, 11:03 AM
You have a 72 with the hard line passing under the front of the engine (by the trans). Disconnect from the oil filter manifold side.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 02-27-2010, 12:02 PM
