Overflow for brake fluid reservoir?
Has anyone come up with a solution for rerouting the brake fluid reservoir vent? I've generated enough heat that in hard, extended right hand turns on the track the fluid will dribble out the vent hose.... directly onto the left front tire and brake. Not a good thing. I've tried rerouting to a catch can adjacent to the master cylinder and still have the same problem but at least it's not getting on the front rotor. In the course of a full day on the track I can transfer half the brake reservoir to the catch can.
I had this problem with the stock brakes and my Hawk HT10 pads (Motul 600 fluid) and it seems to be a bit worse with the 996TT brakes now. Had the same issue with my previous Carrera too. Not boiling the fluid or loosing brakes, not even close. But generating enough heat that I must be expanding the fluid allowing it to slosh around in the reservoir then move out the vent in the right hand turns. Any ideas? |
Can't solve your main problem. But until you do, just run the overflow tube into a small plastic bottle below the reservoir; drain as required.
Ive been dealing with that issue forever. no real solution to cure, but now there is a poland spring water bottle wedged in by the booster with a hose drilled thru the cap. I have been using the jerry rigged bottle setup for a while and think maybe its time to replace it with a more suitable looking replacement.
http://forums.pelicanparts.com/uploa...1267308876.jpg http://forums.pelicanparts.com/uploa...1267308980.jpg |
http://forums.pelicanparts.com/uploa...1267320478.jpg
Here's a photo of what put in. The sports bottle is mounted on an aluminum water bottle holder intended for a mountain bike. |
I use one of my Longacre bleed bottles that has a magnet attached and stick it to the steel body in front of my spare, works perfectly and never moves. Even if it fell over it wouldn't leak as it's sealed..
http://kpi.squarespace.com/storage/t...=1246583418241 |
I route my hose along the fender and through a small hole in the floor pan onto the ground.
http://forums.pelicanparts.com/uploa...1145750170.jpg |
Mr. Ed,
Given that everything is "Cause and Effect",...I think the solution is a multi-tiered one. 1) Reduce the heat: I know you have brake cooling but make sure its getting sufficient air. Don't assume the hose placement has no kinks or obstructions and make sure there are no leaks in the hose. Block-off plates in the hubs are effective. 2) Brake pads. Some brands of pads introduce more heat into the caliper pistons, thus add more heat into the fluid. I'm no fan of Hawak pads for this (and other reasons) so I'd kindly suggest a review here,.....:) 3) Titanium heat plates. I've not used them, but others have had success installed between the pads and caliper pistons. I don't know if there is room or not so this is something to confirm. Hope this helps, |
I also route mine through a handy hole in the bootom of the smuggler's box.:rolleyes: Just the right (small) size for the overflow line.
Not much comes out, just a little drip here and there after sitting after a hard drive where the lateral G's gets it into the overflow tube. |
I think the simple solution is for Ed to slow down!
I have not had this problem (930 brakes, PFC97 pads, cooling ducts with block-off plates). Or, perhaps I just drive too slowly. |
It will overflow no matter what you do if you drive it hard enough. I have mine routed into a catch bottle in the smugglers box which is zip tied firmly in place. This is nasty stuff and if you're on the track you want a setup that is out of the way and securely fastened in the event of an "off". In the smugglers box, the worst case scenario is that it drains out the drain hole.
Thanks all. I've had so many people over the past xx years tell me they don't have this problem that I was beginning to think I was just nuts. At least I know I'm not alone.
For the moment I think I'll stick with my current setup- an extended hose over to an aluminum catch can attached to my stress bar much like most of you have shown in your pics. Steve W- I have air coming directly in from the air inlets in the valance, through the Smart Racing manifolds to carbon fiber backing plates behind the rotors. No kinks anywhere except at full lock. Lots of air moving through there. Though I probably ought to put an IR gun or temp patches on the caliper at some point and measure max temps. Of course the solution is the Smart Racing/Fabcar setup we've chatted about. Mike M- not a chance! I've got to run 10/10's just to keep up with you. |
We use a small brake fluid bottle as a catch can securely mounted
AND start a track session with a cold half filled reservoir. |
Brake fluid
If you get a water bottle with a pull up cap you can remove the plastic in the center and your tube will fit nice and snug. No drilling required. :eek:
PS Don't be like that Scottiude guy with the wedging. A simple velcro wrap will do. :D |
At 1.2g cornering for the DOT-R crowd, that brake fluid is "level" at a 50 degree angle from horizontal, and any sloshing will only add to that. That will certainly reach the vent hose opening.
I don't have this problem, but if I did my first attempt would be to route the vent hose up and directly over the reservoir to the passenger side of the reservoir, and then to a drain or catchbotttle wherever it is convenient to place. Having the vent hose go up as opposed to some horizontal direction would seem to be directionally correct for reducing fluid loss. |
Here's my current setup. I've routed the hose as high as I can and to the rear of the reservoir to avoid or minimize any issue under braking. I'm using an aluminum bottle as the catch can, with a vent hose going straight up. It's tied to the stress bar securely.
(Please ignore the condition of the trunk, the front suspension is off as is the front nose, and the car hasn't been washed since it went up on jack stands a couple months ago.) And to avoid anyone suggesting it, the original 33 bar pressure regulator in the pic is gutted and I'm just using it as an adapter block. http://forums.pelicanparts.com/uploa...1267387520.jpg |
glad to see ur alive. |
I have an interesting observation, does this make any sense?
It appears that all the people with this problem are all 915 gearbox people. I've separately heard from a couple of G50 people who don't have the problem. But the G50 reservoir is significantly different because of the clutch hydraulic requirement. Could it be that the fix is as simple as changing to the G50 reservoir and mounting bracket? |
From our host: Pelican Parts - Product Information: 911-355-017-04-M100 |
http://forums.pelicanparts.com/uploa...1267475777.jpg http://forums.pelicanparts.com/uploa...1267475975.jpg This takes care of fluid expelled by G-forces. If large quantities of BF are expelled, you have other brake system issues (e.g. excessive heat). MHO, Sherwood |
Has anyone ever measured how hot the fluid gets inside the MC reservoir after running hard?
I am surprised that the fluid transmits that much heat all the way up to the reservoir from the caliper. interested in seeing some temp data for this. |
BTW, a friend races his street-prepped car in POC/PCA events and runs his overflow tube into a 35mm film canister. Seems to have enough capacity.
Sherwood |
G50 brake/clutch fluid reservoir photos
Here are a couple. Note that the brake and clutch each have their own compartments, but the wall separating them has holes in it to allow sharing fluid. It should also significantly reduce the amount of "slosh" that will get to the overflow.
http://forums.pelicanparts.com/uploa...1267495943.jpg http://forums.pelicanparts.com/uploa...1267495985.jpg |
Note that the G50 reservoir vent does not originate at the side of the reservoir. There appears to be an internal passage to somewhere near the center of the reservoir.
On the 915 reservoir, taking the vent line out the driver side, routing it rearward, and then up, might not prevent fluid leakage. A RH turn would fill the line, and subsequent accel might push the fluid in the line over the hump. A better solution would be to route it straight up and over the top of the reservoir. It would be difficult to get sufficient g-forces to push the fluid over that hump. Another possibility would be to get some very thin copper tubing that fits inside the nipple and push it through to extend the vent line pickup point to somewhere in the middle of the reservoir where brake fluid is least likely to be. |
Mike- thanks. That helps a lot. Quite a difference from the 915 reservoir setup.
Burgermeister- I tried routing up over the top but it really didn't make any difference. I agree a tall loop up high would be the solution, but the top of the reservoir cap already is extremely close to the hood itself. I may just order the G50 reservoir and bracket from our host and give it a shot. Certainly can't hurt. |
I never had this problem with the G-50 reservoir - But from the looks of these solutions - Number one issue would be heat management. #2 would be fluid management - #3 I'd look for an extra brake bleeding bottle with the magnetic attachment. Seems like the most logical solution.
what would happen if you just blocked off the vent line?
You're correct.
It's called a "vent" for that purpose - route for atmospheric pressure. Sherwood |
This problem can be minimized by running a lower level in the reservoir. I run mine about 1/2 inch below the top. I only drain about 1 oz out per weekend.
-Andy |
I suppose for full-on track driving, lots of laps, G's, heat, etc. I would need something better. |
anyone make a vented cap? Combine that with lower level of fluid?
Can't think of any dire consequences other than the purists wanting to know about the missing plastic. :) Sherwood |
I just did what Sherwood suggested, drilled a small hole in the cap and clamped the overflow tube. Great brakes and no fluid loss and no catch can to empty. Confirmed over a 3 day DE at Watkins Glen.
http://forums.pelicanparts.com/uploa...1337565170.jpg http://forums.pelicanparts.com/uploa...1337565192.jpg |
Anyone gotten further in analysis of this issue?
My SC started life as a '77 2.7, with no vacuum assist brakes. I upgraded with SC flares and a 3.0. I DE's and once raced with slicks, now with Hoosiers. I get around a track fairly well, so am pulling whatever Gs are normal in a pretty fully prepped track car of this type. Then I added the power assist brakes without changing anything else. And I started having this issue. I have to watch the fluid level carefully, and installed a catch bottle to keep from spitting so much out the front. So my suspicions rest on some difference in operation of the power assist MC. I doubt my MC itself is bad, as it was new and others seem to have this issue. Has anyone with an old style, non-power assist MC had this problem? Could the fact that the non-power reservoir is so far away and above the MC have an influence on this? I share the belief that high quality brake fluid does not expand enough to push fluid out of the reservoir. But I don't have the expansion coefficients to hand to quantify this. And if it was expansion which did it, when the fluid reached equilibrium it ought not to expand further, in which case the outflow should stop. Not the case for me. I wonder if reorienting the reservoir so the breather faced rearward would solve this? When I had some instrumentation 20 years ago, I would see maybe 0.33G accel, but about one G lateral and decel. Anyone tried this? I run stainless pistons, titanium plates behind the pads (after they have worn a bit so they can fit), have ducting (yes, not always in the best shape) from front spoiler openings, and the right setup at the brakes. None of this has changed in years. And, as to excessive heat, with the right fluid the fluid does not boil because the pedal, while it might get a hair lower, does not go soft or cause operational problems, even after a one hour enduro. Had to do all this stuff when wife and I both drove back to back run groups racing and first had pedal go to floor. I have changed from Castrol SRF (dry boil about 600F) to Prospeed RS683 (683 dry boil). So I suppose I could be putting more heat into the brakes before boilding. If expansion is a factor, that might make a difference. But for now I am focusing on what I see as the two variables: distance and location of the reservoir, and possible differences in how power assist MCs work. I have some trouble thinking that the power assist system leaves a fraction of time in which there is pressure in the brake lines/mc chambers, but one or both orfices to the reservoir are already a bit open. In addition, that does not seem to explain why, after enough has escaped to the catch bottle, more keeps coming. Any further thoughts on this? |
| All times are GMT -8. The time now is 02:39 AM. |
