mca mca is offline
mca's Avatar
Suddenly Lean - Left Stranded
Cold crank today was way lean - touching pedal resulted in popping, idle was low. I elevated my sensor plate ever so slightly and everything came back to life. Figured the plate was getting sticky and I could address it later.
Car continues to run like a champ for the next 20 or so minutes. Next thing I know the rpms drop while at a light. Spitting and popping ensue. I make it to the next turn off and pull into a parking lot. Running super lean again.
This time moving the sensor plate does not work.
So here I am. Stranded wondering what the issue could be. It runs, but it won't get me home.
Thoughts?
Old 02-27-2010, 10:15 AM
crustychief's Avatar
Maybe some more info? What year? Euro or not?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 02-27-2010, 10:31 AM
mca mca is offline
mca's Avatar
Sorry... using iPhone. 82 sc CIS.
Old 02-27-2010, 10:40 AM
SC-targa's Avatar
Does the fuel pump run if you have the ignition on and you lift the sensor plate?
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 02-27-2010, 11:00 AM
mca mca is offline
mca's Avatar
Solved! O2 sensor relay! So far so good. On my way home.
Old 02-27-2010, 11:07 AM
grateful user
don gilbert's Avatar
the 02 relay gets pretty hot for some reason. They go out pretty often. Most guys dont know it and adjust mix accordingly.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 02-27-2010, 11:53 AM
mca mca is offline
mca's Avatar
Back home now. Looks like my sig doesn't work when using my iPhone.
I was SOOOO close to leaving today without my bag of various relays. Glad I grabbed them ... and glad I had a spare.
Thanks everyone.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 02-27-2010, 11:58 AM
Virginia Rocks!
VaSteve's Avatar
The one under the passenger seat? What happened?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 02-27-2010, 12:13 PM
Paradigm Short Shifter
Send a message via AIM to UrQuattro Send a message via Yahoo to UrQuattro
How did you determine that was the problem? Shot in the dark kind of thing? You had the relay and thought, "I wonder"?
Old 02-27-2010, 12:26 PM
mca mca is offline
mca's Avatar
I always keep extra relays, cdi, coil, etc "just in case" something happens while on the road - I take a lot of long distance trips in it. They are easy to store and certainly worth the effort to have on hand.
Honestly I was in no mood to troubleshoot car issues today. But while I was waiting on the tow truck I called a local Pelican who suggested that I try swapping the 02 relay.
It made sense b/c it controls the frequency valve and all of my CIS is in good order. I really didn't think that it could have been a sudden vacuum leak b/c I rebuilt the engine about 1 1/2 years ago and replaced nearly all of my hoses. Couldn't be the WUR b/c it would not fail suddenly - would be more incremental.
I encourage those of you with later CIS cars to unplug your relay just to be familiar with the symptoms. It will still run but it will be rough.
Old 02-27-2010, 12:41 PM
mca mca is offline
mca's Avatar
Yep, small square relay under passenger seat.
Old 02-27-2010, 12:42 PM
Virginia Rocks!
VaSteve's Avatar
Someone suggested that mine was failing so I pulled the cover off and it looked good inside after 25 years in service. Maybe I'll order a second to have on hand.
I have a motronic 944 and don't leave home without the spare DME relay!
Old 02-27-2010, 03:04 PM
T77911S's Avatar
sorry i missed your call. i was working on the house. tim was up helping.
man, you have had some issues lately. mine started doing the same thing friday. no idle at all in the morning but it was fine going home.
this is one of the advantages of the earlier cis systems, no electrics to leave you stranded. as long as my fuel pump and cd work, im good to go.
i keep the spares tucked awayy in fornt of the spare tire, wrapped in a towel. dont tell the wife, its one of her good ones.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-01-2010, 06:03 AM
