Sanity Check...Oil Leak
My 1984 Targa is leaking a lot of oil. I checked all the "usual suspects", as did my tech. We both feel it is the oil return tubes, which I plan to replace this weekend. The prior tubes have been on my car for about seven or eight years. Is it normal for them to start leaking again in this time period?
Thanks in advance.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 03-02-2010, 06:43 AM
muck-raker
kidrock's Avatar
I guess the first question would be, where does your leaking terminate? At what point from your car is the oil hitting the floor?
If it's not immediately noticeable (and it rarely is), you may need to give your motor a good cleaning. Then, you can more readily trace the leak backwards towards it's source.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 03-02-2010, 09:45 AM
Mo money = mo parts
I'm not sure there is a "normal", but 8 years would reasonable life. There are a lot of variables that could effect how long they seal well.
I would make sure that you thoroughly clean the area of the cam tower and case where they install, then use a silicone grease to slide them into place. The steel collapsible tubes, not the aluminum, are considered to be a better choice for replacement. The male portion of the tube should be adjacent to the cam tower. It's pretty straight forward. Waaaay easier with the heat exchangers removed, but doable with them on.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 03-02-2010, 09:47 AM
You can change just the return tube seals if you have the collapsable ones.
Old 03-02-2010, 11:41 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks in advance.
Check the recent post on '87 oil leaks.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-02-2010, 11:44 AM
Actually, I have cleaned and analyzed the entire engine. Just did a ton of work. T-Stat and Oil Pressure switch are fine. Followed up with an eyeball from my technician. We both agree that the oil return tubes could use a replacement.
All I am asking is for some feedback from others that have experienced the same issue. I read the "How To" where the 914 Owner's car dumped all the oil overnight. But that sounds really extreme.
Since I have already tried the steel tubes, I have switched to the aluminum, which were highly recommended by my technician.
Based on my last experience with this replacement, I have placed the tubes in the freezer and have plenty of Sil Glide ready to go.
Sorry for the ramble. I was just doing one final Sanity check.
Old 03-02-2010, 01:36 PM
dshepp806's Avatar
Tha Aluminum ones are fine.....
If it's leaking from the return tubes, shouldn't this be easily "seen".....?
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-02-2010, 02:55 PM
Best,
Doyle
Unfortunately, the final check was done right when the oil was clean. Doh!
But now after my last reply, I did read the thread on the other oil leak, and "Double Doh!!!", I never checked the breather line.
Why are all you smart folks tormenting me with new places to look for leaks?
Old 03-02-2010, 03:50 PM
Because of the direct interface with the engine (heat), the oil return tube gets very hot and cracks.
When I removed/replaced mine last year, along with the other gaskets, it literaly came apart at the engine interface.
1986 911 Targa.
Only in L.A.:
Old 03-02-2010, 04:04 PM
