Transmission dissasembly question
I'm almost through part one and decided to call it an evening when I could not get this post or washer out/off to remove the last gear. It looks like there is a lock ring in the picture but I'm quite sure its just the camera light. Can anyone coach me through the last step in the cone? thanks Doug
Doug 97 C2S 993(last one) 95 993 cab- 85 911 M491 87 944 Turbo- 70 914-6 63 911 |
That post is called the Reverse Idler Pin, it just drops into the hole. You are there. Grab the gear and pull both the gear and the idler pin up at the same time. They come out together.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
