-   -   Steering Noise Question (http://forums.pelicanparts.com/porsche-911-technical-forum/529348-steering-noise-question.html)
Helios59 03-04-2010 08:07 AM
When I turn the wheel at low speeds (i.e. parking) I've started to hear a "grainy" sort of noise...for lack of a better term. No squeaking, no popping, no grinding. Something may be rubbing against something else, or maybe something just needs lubrication. It actually sounds like my knee when I flex it (you guys of a certain age know what I mean).
From doing searches, I'm guessing it may be bushings or horn contact needing grease...any other guesses?
I haven't experienced any problems with the steering, it's fine...I just want to diagnose the noise. Thanks.
tomphot 03-04-2010 08:39 AM
I think it's the steering bushing starting to break apart. That's what mine sounded like before it completely broke apart - I then started to get side to side play.
Look at this thread..http://forums.pelicanparts.com/porsche-911-technical-forum/480462-mitch-lelands-steering-wheel-bushing.html
I bought the bushing that Mitch makes and all is well - an easy fix.
daber88 03-04-2010 08:54 AM
Mine was making scraping noise like you describe while turning the wheel during low speeds. I took the wheel off and could see where the horn contact was scraping the copper. There were little shavings all around the contact strip. I put a little di-electric grease on it and it went away.
Hope that helps!
-Derek
