simple pedal cluster question
I want to adjust the accelerator (gas) pedal linkage and don't want to hurt the wooden panel in front of the pedal cluster. Is there a right way to remove it?
There is one nut holding it in place, at the bottom. At the top, there are 2 slotted holes that go over metal u shaped pieces. You will need to remove the gas pedal linkage form the pedal to remove the board.
Thanks!
Removing the rubber pads on the brake and clutch pedals will help to allow the pedals to pass thru the holes in the floor board.
+1
| All times are GMT -8. The time now is 10:08 PM. |
