trying to resurrect..no fire.....
.....Ignition box is whining away--no power to coil..What do i test next?? Hmm one issue at a time and i will get this thing fired one day!!!
thanks guys |
Hi,
Welcome to one of hte best BBS for air cooled porsches. help us out a bit by adding your location to your profile and tell what year/model 911 you have. This thread may be helpful: Ignition problem troubleshooting (electrical)...... Also, from another thread (How do i check a coil with a timing light?? Quote:
Wow what great help --thanks... I do hear the wining from the CDI but it doesn't seem the coil is getting the signal. Still doing some checking..Also, with key in run position there is no voltage getting to coil. BAD CDI??
thanks again Last edited by indasevens; 03-06-2010 at 05:32 AM.. |
indasevens,
You really have to tell us what kind of car you are working on. The ignition systems changed quite a bit from the 60's to the 70's and into the 80's and 90's. In general, you cannot measure voltage at the coil if you are using a CDI box.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
so sorry....I have a 71 911t. Hasnt run for several yrs.
Do you have points or some type of electronic breaker on the distributor?
indasevens,
You should have a 3-pin CDI just like mine. Hearing it whine is a good first step, but the instructions HarryD has shown are the basic ignition checks you will have to make. In particular: 2) Verify that the CDI is producing power to make a spark. You can do this with a "telegraph" test. Take the high tension lead off of the center of the distributor and put a spark plug on it. Ground the threaded part. With your plug attached to the center lead, open the distributor, remove the rotor, place your key in the run position, and manually open and close the points. Each time you cycle, you should see a spark from the plug. If you do not, you may have a bad CDI. This is an excellent test of the CDI, and combined with the other instructions, should lead you to a working ignition system. Best of Luck.
I think i simulated that test by checking spark from coil when turning motor over and did not get spark---I check under the cap and the "points contact was actually breaking so.......still searching..Maybe i didnt perform test properly though
Don't overcomplicate. When troubleshooting, a stepwise approach is best and will lead you the end most effectively.
Do the "telegraph test" as I stated to remove any extraneous factors.
YOU GUYS ARE GREAT!!! Did the test and the spark plug "lit" everytime the "points" broke contact.....Getting excited here...now what???? LOLOLOLOL
NO SPARK on second test...only when i manually break "points"..Turn motor over and no spark..
OK guys let me explain more....I did the first test and got spark..but realized it was because my little screwdriver was touch other "areas" and causing the spark to the plug..when i move the distributor enough to just break the point it doesn't spark.....hmm not sure what that means--
Have you set your point gap correctly? Gotta ask, sorry.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Never "set" them but just got done cleaning the contacts and GUESS WHAT..spark..all the way to the spark plugs...Once i get it running and know it at least runs. I will go back and invest in new wires, cap rotor, etc, etc,
thanks again guys |
Let us know how she runs.
I'm surprised no one has mentioned fuel. Is this new fuel or old? Did you dump the old or just mix it with new? The old fuel could give you a hard start or no start at all. Just something to think about.
"Work harder........... Millions on welfare depend on you" " If you aint cheaten you aint tryin" |
OK spun it over for first time and NOTHING.. I hooked up a temporary fuel lines with fresh fuel in it. Again, once i hear it atleast run then i will go through all steps of flushing tank and all lines.
Every once in awile it acts like it wants to start but still nothing. Its one step at a time i guess! |
Set point gap and set static timing @ TDC to see if she will start.
Be sure the clean fuel is actually going into the carb throats. If she starts and runs, set timing to 35* BTDC@6000rpm.
Your car should have originally come with Zenith carbs. Do you still have carburetors on it? If so, they may need a good cleaning from not have run for many years.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL Last edited by Walter_Middie; 03-07-2010 at 02:36 PM.. |
YES the zeniths are still on it. I guess i need to rebuild them huh....ARGGGG
