Can't start my Engine???
Hello,
Well heres the situation....The 75 2.7 has built to 2.7 RS specs ("S" MFI, "S" cams, RS Pictons and Approx 260HP dyno) has sat for over 2 yrs. and I had it running for 10-15 seconds on two or three cylinders. I have changed the distributor cap, rotor, points, coil, fuel pump. It has spark at the plug and it is getting gas... Oh yeah I found out the other day the compression was off 1. 115 2. 125 3. 125 4. 75 5. 75 6. 100 but now they are all right around 150. So now I ask for help on how to get it running. I have the belt for the fuel pump timed at the #1 cylinder and not #4 but as I understand it that would only inhibit power under 2800 RPM. I am going to pull the engine as soon as I can get it running (To check out the transmission)... Thanks For Any Help, Ron
1969 Porsche 911 S - Only one and its For Sale
You do not have permissi
Are you sure it's getting fuel? Is the gas ok and not full of rust?
I'm not familiar with your engine but with cis you can usually pull an injector, jump the pump relay and watch for a nice spray. Does it have any sensors which need to be cleaned etc... Does it have enough cranking voltage to fire under load? Just some ideas.. good luck |
