1984 Carrera Coupe 3.2
Harbor Freight Battery Charger
Hi folks, Has anyone purchased the HF battery charger/engine starter?? It's lot no. 66783, and says 10/2/55 amp, 6/12 volt and is currently on sale with a coupon for $25. I did a search and found quite a lot on their float chargers, but nothing in regards to this. I'd like an all-purpose charger for the 911 as well as misc. vehicles from vintage tractors to bikes and antique jeeps. Thanks much!
Yes, I have had one for years now and it has served me flawlessly.
While I believe in always trickle charging, the 55 amp jump setting has saved my bacon more than a couple occasioins. Hope this helps...
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
I have one of those. Charges ok. Wouldn't use it for starting tho, but to be truthful haven't tried.
Old Tee all 911s sold |
Mine didn't work straight out of the box.
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
cycling has-been
spend the extra $30 bucks and get a Vector with smart technology. Looks like you are going to use it on a variety of applications, so the peace of mind would be worth the $$.
I've had a std charger fry my charging system, (okay, mostly user error), but now I'm better safe than sorry. my .02 Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
I swear by a C-TEK XS-800 trickle charger. Never failed me and conditions the battery as well. I would spend a little bit more if I where you.
'71 911 T Original Burgundy |
If you buy it, keep it as far from the car while using it as possible...
I've seen some Harbor Freight electrical tools blow up in sparks and smoke in a rather dramatic way. At the same time some of their stuff works good and is a bargain. |
FWIW.....I bought a trickle charge Schumacher from Walmart for $20.00 and it works like a champ....
Sean M '77 911S Targa Ice Green |
Jupiter 911
I bought the sears Die Hard trickle charger for $25.00 it charges and floats. Comes with both the clips and the eye clips so all you have to do is plug it in, not bad. Seems to work real well.
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
Jumping a dead battery with either a booster battery or high current charger always results in the vehicle alternator to create full output to recharge the discharged battery. In a 911, this often results in shortened alternator service life.
It's recommended to fully charge the vehicle battery before cranking, and for that, all you need is a trickle charger or, for longer term storage, a battery maintainer. The HF units work, but there's a question as to the longevity of some models. I have permanently connected the HF battery maintainer, the model with a recessed 110VAC cord connector, and it has worked fine for about 3 years thus far (about $15). I just looked and the model described above is NLA. Other models may be equivalent. Harbor Freight Tools Sherwood |
