three wired Oxygen sensor
I just bought a bosch universal 3 wire oxy sensor. I have to cut the wire coming from the 3.6 liter harness(did . I heard all three wires do not have to be used, is this true. there are one black and two white. does anyone know why there are three.
Old 11-27-2001, 10:07 AM
There are three wires because it is a heated sensor.
Charlie
'72 911T
Old 11-27-2001, 10:17 AM
ground, +12V, and signal.
I have one on the way for my 200tq20v, which uses all three. They often include heaters to speed up reading accuracy when cold, thus 3 or even 4 wires.
Charlie Baer
'79 Euro 911SC (Guards Red)
'83 Quattro (Mars Red)
Old 11-27-2001, 10:25 AM
Jim Smolka's Avatar
On most 3 wire Bosch type O2 sensor, the two white wires are for the heating element. The polarity does not matter. The black wire is for the signal.
On 4 wire sensors the extra wire is for the ground path for the signal wire. This way the ground does not have to go through the exhaust system thereby reducing noise in the control circuitry. This is a good thing that Ford started requiring on their cars in the late 80's and early 90's especially since the O2 signal is typically less than 1 volt.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 11-27-2001, 10:44 AM
Thank you guys
So will any type of connector will do, I dont have the original
Old 11-27-2001, 11:54 AM
Jim Smolka's Avatar
The ideal thing would be to use the old connector from the old O2 sensor and spice that connector onto the new O2 sensor. If you don't have the connector, you might try to find someone who has an old sensor (P-car shop or a Pelican parts wanted BBS)
Old 11-27-2001, 12:19 PM
Mine arrived today, it has anti-sieze on the threads and a plug attached. The plug looks a lot like a mic XLR with 3 round pins at 9,12 and 3 o'clock in a round housing.
Any idea who would have a mating socket to fit ? I've been looking through the Audi/VW ETKA and haven't seen anything that might work.
Now don't tell me to just lop it off and crimp it to the old wires, I get my kicks by socketing everything!
I just noticed, even the cardboard box has a Bosch part number.
Charlie Baer
Old 11-27-2001, 04:18 PM
Senior Member
Hello
The rubber sockets are showed in the spare parts catalouge and can be ordered as repair set.
Grüsse
Old 11-28-2001, 04:22 PM
What spare parts catalog
Old 11-28-2001, 04:34 PM
Guys,
I replaced the o2 sensor in my 87 last Summer.
Um, ah, went with the generic Bosch model, figured, no big deal, I will remove the generic connector and solder the old connector in it's place and live happily ever after.
Didn't work that way as the wires are stainless and solder will not stick to stainless. I spent hours searching for spade connectors and crimped them to the old connector and the new sensor wires.
Should have got the Porsche sensor. Right plug, plug it in, job done.
Hi Roland, offer still holds.
Ned Monaghan
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 11-28-2001, 04:37 PM
