Brake issue, 84 Carrera
Hello all. I have been having some brake issues lately and am very stumped as to what the problem is stemming from. When I push the brake pedal in it feels like I 'hit' something and the pedal stops. Definitely not hitting the floor with the pedal but something about half way.
I have replaced all the brake lines, including the pre-bent metal lines, replaced the master cylinder, and had the lines vacuum bled by my shop. Don't think its air in the lines. I rebuilt the calipers a while ago too. The rear brakes seem to be working harder as they are wearing faster than the fronts. At about half pressure the brakes work fine. While going slow I can push the pedal in till it 'stops' and it feels like Im slowing down in an SUV, cant lock anything up even if I tried. Almost ran into the back of a car this weekend when I needed to stop and just slowed down. Definitely puckered up a bit! So, do any of you experts have any idea what could be going on? Brake wise its a stock 1984 Carrera 3.2
Joe Riley IV 1984 3.2 Carrera Targa |
DO NOT DRIVE THE CAR UNTIL YOU GET IT FIXED. Don't take a chance of hurting someone or yourself.
Did you replace the rubber brake lines? If not, do so. To me, it sounds as if the rears are doing all of the work instead of "assisting" the fronts. I would pull the front wheels and have a helper push the pedal and see if the front pads are coming out to touch the rotor. I suspect they are not. Also, check your brake lines for any bulging or sponginess as the helper pushes the pedal. The question is why?
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Brake lines have ALL been replaced. No sponginess in the pedal, it just gets to a point and stops, feels like it actually hits a stop but does not go to the floor (not that bad.) The brakes work fine under normal conditions but in emergency conditions it stops like my old Chevy Silverado. Definitely looks like the rears are doing more of the work...
Almost sounds like the front pads have glazed. Put in new oem pads and see if it is any better.
since I noticed the issue a while ago and started to self diagnose I have since changed the front and rear pads when I rebuilt the calipers. The thing that stumps me is the feeling of the pedal hitting 'something' on the down stroke...
Have you pulled up the floor board and checked for an obstruction?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Have you checked the pedal cluster and all of the linkage between the brake pedal and the brake booster? May be a mechanical issue, not a hydraulic issue.
Ill take a closer look at the cluster in the morning. Thanks, I hope its something simple!
I had an identical symptom on my '80 SC. Tried everything with no luck, till I changed out the master cylinder. Voila! had super brakes once again.
your problem may be something else, but sounds like you've tried everything else! EDIT: just reread your post and saw you replaced the MC, maybe the new one is defestive. Just guessing.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 03-08-2010 at 08:33 PM.. |
I'm here to cause trouble
Well given that you're from Florida, I bet you'll find that missing Titleist that used to rattle around under the seat...
Did this just start suddenly one day and remain constant, or have the symptoms changed over the period of time we're dealing with here? JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
defestive: a master cylinder that does NOT like to party....
Thanks for pointing out what might be the obvious problem, Pete.
Jim: LMAO!! I play with Nike balls but regardless, Ill have a look under the floor board and around the cluster/linkage to see if its an obstruction.
Uwanna: I was kind of thinking it was a defective MC too, if all else fails Ill replace it again. Heading out there right now to have a look and will post any new findings in the next few hours. Thanks for the help everyone!
Hey, I had the same problem on my 1984 Tagra. Every time I would hit the brakes in the rain, the ass end would slide out. And when I went to the track, I would go through rear pads quicker than the fronts. I needed a new proportioning valve. It s right in the smuggler's box, and will take more time to bleed the system afterwards than to replace. It is a hundred dollars, but then again, do you really want to waste time screwing with the MC again? Here is the link:
Pelican Parts - Product Information: 928-355-305-02-M100
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
My two thoughts are:
- Check the pedal cluster for obstructions and worn bushings - Proportioning valve |
Rear is not locking up, it just seems (by looking at the pads) that they are doing more work than the front. Still think it might be the proportioning valve? Im kind of convinced that somehow there is air in the lines, maybe in the MC itself... Someone PM'ed me about a spare proportioning valve he had, if its a good deal you think I might as well install it or try some more bleeding before spending money?
Put in the new proportioning valve. If that is not it, then you can bleed some more. If the valve is a good deal, just do it and eliminate one more possible trouble area.
Tell us about your rotors. Sounds like you have rebuilt the calipers and changed the pads. Did you check the rotors for run out? Dished or grooved rotors can impact brake feel and cause the pads to glaze. This would make it stop like a Silverado. I can relate, my wife has a Chevy Tahoe and the brakes feel like a wet sponge under hard braking.
In my Carrera I was going insane trying to figure out why I had such a lousy pedal feel under hard braking. Like you, I had new pads, fluid, brake lines, and a new master cylinder. I was just about to change the proportioning valve when I decided to check the rotors. Sure enough, the front rotors looked good but were severely dished. New rotors and pads all around turned my car from a Tahoe into a track star. Just curious when you replaced the master cylinder did you also replace the booster? Randy
1986 Carrera Targa - sold 1987 Carrera Coupe - sold 2003 Twin Turbo - sold 964 Coupe - on the hunt |
Northern Motorhead
Just a shot in the dark...
I read something about piston orientation when you rebuild the calipers,could that be an issue in your case ? Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
