Newlin4141's Avatar
Porsche Crest Broken Targa Bolt Situation
Trying to remove the Targa top from my 1975 911 and… snap! It's the two-pronged "bolt" into which the handles go to affix and lock down the roof to the front windshield. It's an old part but I wasn't applying too much pressure. I've attached two pics. One is the left drivers side that is correct and unbroken. The right passenger side is the broken one. No idea how to even get the targa off now without doing further damage. Just in time for Spring, right? The top was stripped down and restored 4 years ago but none of the metal parts were replaced.
Ugh. Any ideas?
[Sorry for the huge pics]
1980 930 Turbo
2003 Audi S6 Avant
1975 Targa 3.0 – Sold.
Old 02-14-2010, 12:28 PM
Paradigm Short Shifter
Send a message via AIM to UrQuattro Send a message via Yahoo to UrQuattro
I found a solution for just this problem. Lemme find the thread which has the answer. In short, that split locking bolt can be removed and replaced by the part I'll find for you. Only thing is that it is not a factory part, and it takes some courage to do. You'll have to open up the lockitself in order to get to it.
Michael
Old 02-14-2010, 01:04 PM
Question about the release lock on my targa top - ie. broken slot for the handle
Regarding the release mechanism for the targa top, ie. broken slot for the handle
Old 02-14-2010, 01:07 PM
steely's Avatar
nice find Michael - significantly cheaper than replacing the entire top latch!
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 02-14-2010, 01:14 PM
Newlin4141's Avatar
Wow. God bless the Pelican Forum. Amazing find. I tried to find something in previous posts and didn't come up with anything. Awesome. Thank you very much Michael.
John
1980 930 Turbo
2003 Audi S6 Avant
Old 02-14-2010, 01:36 PM
Newlin4141's Avatar
So wait re: your posts, did you ever get it fixed on your own or did your mechanic figure it out?
1980 930 Turbo
2003 Audi S6 Avant
Old 02-14-2010, 07:08 PM
My mechanic ended up figuring it out. It cost me about 1.5 hours of labor. So, a lot less than a new lock.
He said that the hardest part was bending the metal that is folded over to keep the two halves of the lock together.
But, I haven't had any problems using the targa top on my car once i got it back.
Old 02-15-2010, 12:16 PM
Newlin4141's Avatar
Ah, I see. Yeah, this seems like it might require the work of a professional, given my proclivity to make matters worse when attempting repairs.
Again, thanks for the input.
John
1980 930 Turbo
2003 Audi S6 Avant
Old 02-16-2010, 10:13 AM
Targa Top problem
Couple choices.
1. You can try a screw driver to turn latch receiver
2.You must remove the vinyl cover on the arm. Once this is done you can use vise grip pliers to loosen bolts
3. Did the latch break because of a damage handle or was seal replaced?
Dan Petchel
CarsincNJ.com
Targa top Restoration
Vintage parts
609 298 2277
carsinc@comcast.net
Old 03-09-2010, 07:09 AM
Certainly replacing the latch or replacing the part is the best way to go but many years ago I had the same thing happen. I drilled a 1/4" x 1/4" hole in the center and epoxied a torx head in the hole. I used a 1/4" ratchet to open and close the latch. It didn't look the best but it worked great for many years.
Old 03-09-2010, 08:20 AM
Tags
targa , targa top
