-   -   Gearbox problem (http://forums.pelicanparts.com/porsche-911-technical-forum/530369-gearbox-problem.html)
Jan 911 03-10-2010 04:13 AM
Gearbox problem
Hello All,
I have a problem with my gearbox ( type 915 - Porsche911 SC 1982 )
During a ride through the city, I can change all the gears without any problem, but
when I drive on the highway and stay for longer time in fifth gear, it is very difficult to return to 4th gear. I must pull very hard on the lever. Has anyone any experience with this problem?
Kind regards, Jan
twistoffat 03-10-2010 04:34 AM
I´ve heard of this problem before on 915 boxes. Its apparently a worn hub catching the shift sleeve.
twistoffat 03-10-2010 04:36 AM
Just found this older post. Its mentions the sleeve but also other possibles
http://forums.pelicanparts.com/porsche-911-technical-forum/166247-915-requires-force-remove-5th-gear.html
Peter Zimmermann 03-10-2010 07:55 AM
Originally Posted by Jan 911 (Post 5227789)
Hello All,
Kind regards, Jan
It's all about technique. Never leave the car in 5th at speeds below 55 mph, and you will never experience the problem again! Simply change from 5th to 4th as you decel to below 60...problem solved!
...unless something really weird is going on.
john walker's workshop 03-10-2010 08:50 AM
notched (worn) 5th/reverse hub is the usual problem. seen some pretty bad ones.
mack6820 03-10-2010 09:34 AM
I could never drop from 5th to 4th, I always have to bring the shifter up to third, then down to 4th.
john walker's workshop 03-10-2010 10:17 AM
that sounds like more of a shifter adjustment issue.
Helios59 03-10-2010 12:53 PM
Since we're on the subject of 5th gear issues, how about this:
I have a difficult time finding 5th. Sometimes the shift goes smoothly, but last weekend the shifter got stuck in 5th. I was able to yank it back down to 4th - pausing in neutral first, of course - but don't want to repeat the experience.
Recently replaced pedal bushings, shifter bushings, shift cable, and helper spring. Clutch action is great and synchros seem good other than first gear being a bit balky from time to time. Synchros replaced about 25K miles ago, long before I bought the car.
Worn hub?
