Jtilden's Avatar
Am I Hearing Things...Or Is My Fuel Pump Humming...
While my car was idling I noticed a humming noise coming from the front of the car. Upon further investigation the noise appeared to be coming from the fuel pump area...does this mean it is about to give up the ghost? (die, croke, stop working)?
95 993 Cab
99 996 C2
80 911SC Targa
85 944 N/A(sold)
Old 03-10-2010, 05:53 PM
RETIRED
Joe Bob's Avatar
Fuel pumps hummmm.....
2012 ML350 3.0 Turbo Diesel
Old 03-10-2010, 06:23 PM
Senior Advisor
James Brown's Avatar
When I first got my car, I thought it was a vacuum leak at the booster, turns out it was the fuel pump. That was 4 years ago, it's still going strong, don't worry about it, worry about your head studs.
08 Cayenne Turbo
Old 03-10-2010, 06:32 PM
DW SD's Avatar
my pump makes more noise when it works harder. It gave me an indication the fuel filter was plugged. I have a pre-filter and one in the engine compartment. Sediment was coming from foam bits in the fuel cell. I might suggest checking the filter and also the screen on the tank.
Doug
1971 RSR - interpretation
Old 03-10-2010, 08:09 PM
I've seen a lot of 911 fuel pumps fail in the past 3-4 years. I think it might be related to the crappy gas now days.
Old 03-10-2010, 08:15 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
a hummer is always a good thing. its when u turn the key and dont hear the hum is when you are screwed.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 03-10-2010, 08:20 PM
