AutoBahned
I'm sure the anti-exercise advocates are thinking of the m/c and analogizing to the calipers... |
Somatic Negative Optimist
Analogizing calipers??
How about: "Bilateral symbionic molecular fusion" ![]() Changing brake fluid and bleeding the system is a very simple procedure; no need for great expertise or a College degree. ![]() A lot of street cars go for years with the same pads and fluid meaning the caliper-pistons stay virtually in the same place. It's a law of nature that moisture in oils sinks to the lowest levels which are the calipers. And that means the pistons can and will seize. It also means that the intended retraction of the pistons due to the square-seal design is not happening. Result: The pads stay in close contact with the rotors creating unwanted heat and wear. If that doesn't make sense, then don't ever exercise the pistons, never pump the MC and just rebuild the calipers more often. ![]() Do what feels good. ![]()
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() Last edited by Gunter; 03-18-2010 at 06:57 AM.. Reason: Gobbledigook |
Pentosin "Racing Brake Fluid" 200 C degrees (392 F) wet, 300 C degrees (572 F) dry, which is considerably higher than ATE Blue/Gold and is $16 per liter at my Loveland, OH auto parts store.
I bet there isn't anyone out there who could tell the difference between Pentosin Racing and Motul RBF 600 (216 C/312 C), except the Motul is almost three times more expensive. ![]()
1987 Carrera 3.2 |
I don't agree with your "dare". 12c is over 50f, which is not insignificant. I'm also not sure how you figure 3x difference in price, maybe twice as much-which works out to maybe $15-chump change IMO.
You guys are wimps. Just use your thumbs/fingers.
1987 Carrera 3.2 |
We have found on more than one occasion that switching from ATE to Motul solved the fade problem for stock braked Carrera's at DE's.
Not saying it is a cure, just that for the use that these cars were seeing, it made a difference, a big difference. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
