3.2 "lazy throttle"
Now that my engine cover can be opened I can Investigate a few minor problems.
After reading an earlier post I know I am not the only driver who double de-clutches on the road. However occasionaly when coming down thro' the gears the engine seems to "bog down" when I blip the throttle. Sequence Select neutral, release clutch blip throttle, then foot on clutch - revs stop at 3,500 -4,000rpm blip throttle again select gear I am careful that my fott does not catch on the wheelarch intrusion. Operating the mechanism at the engine end works OK. Any ideas, new cable/ adjust linkage etc or more sinister injection gremlins. While I'm on the subject, does everyone get "popping" from the exaust between gearchanges (up and down?!). I am running on super unleaded 97 octane, car is set for 98 I believe. Rob:o |
